Hewlett-Packard Sprout 23-s010 all in one pc bios dump
  • HPSproutUser
    • Jan 2021
    • uk
    Hi all, hugely appreciate if one of you could help me with a BIOS dump for the Hewlett Packard sprout 23-s010 pc, I ended up applying the incorrect bios update, and further aggravated the problem when I flashed the bios chip. So would be grateful if someone who owns a sprout pc or some spare sprout motherboards could get a bios dump, thank you !
    The motherboard part numbers are IPPHW-ML 741090-001 /741090-501/ 741090-601.
  • qayyum786
    • Aug 2018
    • 1959
    • INDIA
    Re: Hewlett-Packard Sprout 23-s010 all in one pc bios dump
    Originally posted by hpsproutuser
    hi all, hugely appreciate if one of you could help me with a bios dump for the hewlett packard sprout 23-s010 pc, i ended up applying the incorrect bios update, and further aggravated the problem when i flashed the bios chip. So would be grateful if someone who owns a sprout pc or some spare sprout motherboards could get a bios dump, thank you !
    The motherboard part numbers are ipphw-ml 741090-001 /741090-501/ 741090-601.
    try
    • rconnor
      • Oct 2023
      I need to reflash my Sprout bios on chip, but which IC is it on the board?
      Anyone help?
      • peste
        • 13550
        • ROMANIA
        Anyone help?
        take a clear picture of the motherboard and post it here..
        • Ahari
          by Ahari
          I...
          08-13-2025, 06:12 AM
        • mkdj
          by mkdj
          Dear all,
          10-19-2025, 04:41 AM
        • Habble7
          by Habble7
          Suspected Cause:
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
        • haitham sharabati
          by haitham sharabati
          Hello engineers 😀,
          🔧 Device Info:
          - Model: HP 15-da2007ne
          - Product Number: 8XF55EA#ABV
          - Serial Number: CND0338P0D
          - CPU: Intel Celeron N4000
          💀 Problem:😅
          08-07-2025, 04:54 AM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
