HP Cromebox DA00W9MBAD0 Rev. D
  • Pascal Komlassan
    • Jan 2017
    • 809
    • TOGO
    hi
    need HP DA00W9MBAD0 Rev. D bios for windows
  • peste
    • 13566
    • ROMANIA
    Re: HP Cromebox DA00W9MBAD0 Rev. D
    Originally posted by Pascal Komlassan
    hi
    try..
    • macabook
      by macabook
      đź§© Initial Issue
      07-24-2025, 02:17 PM
      by Vesko356
      08-11-2023, 03:27 AM
    • abel2b
      Hello, Can anybody help with how to recover DMI and Windows Key from HP 14-DQ1004LA Bios
      by abel2b
      Can someone teach me how to edit New *.bin with DMI and Windows Keys from broken bios.
      where should I look (OFFSET) in old dump?
      What must be copied to make new functional bios?
      MY machine is:
      HP 14-DQ1004LA
      S.N: 5CD0080M17
      Background: Tea was spilled on my notebook accidently I imediatly, turned off, unplugged and opened to disconnect battery, I cleaned everything thoroughly, I checked all power supply coils for shorts and all good, except Vcore coil ohms at 0.1 ohms, but I searched around and it seems it is ok. I powered up the board , and all voltages...
      06-30-2025, 09:54 AM
    • 0xx
      2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
      by 0xx
      Hi folks,
      My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
      What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
      I assumed that Windows Update was interrupted due to closing...
      09-14-2025, 03:46 PM
    • jbonavita
      by jbonavita
      Some issues
      Things I tried
      04-29-2025, 09:38 PM
