STRIX B250G GAMING bios dump help
  • lesterbrazal
    • Aug 2011
    • 38
    STRIX B250G GAMING bios dump help i cant find dump file its not same if you download it form main website thanks
  • peste
    • 13562
    • ROMANIA
    Re: STRIX B250G GAMING bios dump help
    post the bios backup and the full name and model ..
      • 21841
      You can cut the cap header with a hex editor, offset 0 - 7FF Length 800 , or use UEFITool.Open bios with UEFITool ,right click on AMI Aptio Capsule - Extract body .
      https://rog.asus.com/uk/motherboards.../helpdesk_bios
      https://mh-nexus.de/en/downloads.php?product=HxD20
      https://github.com/LongSoft/UEFITool..._A58_win32.zip
      • Ahari
        by Ahari
        I...
        08-13-2025, 06:12 AM
      • mkdj
        by mkdj
        Dear all,
        10-19-2025, 04:41 AM
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • haitham sharabati
        by haitham sharabati
        Hello engineers 😀,
        🔧 Device Info:
        - Model: HP 15-da2007ne
        - Product Number: 8XF55EA#ABV
        - Serial Number: CND0338P0D
        - CPU: Intel Celeron N4000
        💀 Problem:😅
        08-07-2025, 04:54 AM
      • Rhaverz
        Bios for ROG-STRIX-RTX2060S-A8G-GAMING
        by Rhaverz
        Buenas amigos, estoy buscando a un colega que tenga un bios funcional para esta ROG-STRIX-RTX2060S-A8G-GAMING, busqué en otro foros pero el bios no esta funcionando y solo hay para otro tipo de rog strix que no se son compatibles, mi VRAM son Micron.
        Gracias por la ayuda!
        Good friends, I am looking for a colleague who has a functional bios for this ROG-STRIX-RTX2060S-A8G-GAMING, I searched in other forums but the bios is not working and there is only one for another type of rog strix that is not compatible, my VRAM are Micron.
        Thanks for the...
        02-04-2023, 03:21 AM
