GA-B150M-D3H DDR3 (rev. 1.0)
  • eniac22
    • Jun 2012
    • 124
    • Greece
    Hello,i need GA-B150M-D3H DDR3 (rev. 1.0) .bin file
  • peste
    • 13562
    • ROMANIA
    Re: GA-B150M-D3H DDR3 (rev. 1.0)
    bios extracted from the site update make a backup before writing the bios chip ..
    • eniac22
      • Jun 2012
      • 124
      • Greece
      • OKRPKCOMP
        • Dec 2020
        • 439
        • PAKISTAN
        Pls repair bios
        GA-B150M-D3H DDR3 VER 1.0
          • 21841
          Originally posted by OKRPKCOMP
          Pls repair bios
          Flash the bios at post #2 to both chips.For retail motherboards always check the manufacturers support page,the full bios image is usually available
          • OKRPKCOMP
            • Dec 2020
            • 439
            • PAKISTAN
            Thanks sir its working
            before that i have flash above bios in only m-bios chip
            Its working but display hangs at startup, so i request
            Now at yours kind advice, i flash the same bios to b-bios chip also
            Now its working fine
            Thanks again
            • m1ch43lzm
              by m1ch43lzm
              Hi everyone
              09-06-2025, 05:47 PM
            • to5it0
              by to5it0
              10-24-2025, 01:35 AM
            • Forest79
              by Forest79
              07-23-2023, 07:39 AM
            • Citymin
              by Citymin
              S/N : 5RNK9FFT70...
              08-05-2025, 05:12 AM
            • elmoori
              .FD BIOS file for AN515-56
              by elmoori
              I’m trying to recover my Acer Nitro 5 AN515-56, which currently has a corrupted BIOS and won’t boot. I’ve searched Acer’s website and all I can find is the official BIOS update .exe file.
              Inside that .exe, I managed to extract a file called abobios.bin, but there is no .FD file available — the one needed for Acer Crisis Recovery.
              I’m looking for someone who has the original .FD BIOS file for this exact model, or any guidance on how to extract it safely from the official update.
              09-18-2025, 05:34 PM
