Q65h2-ad bios plz
Q65h2-ad bios plz
Every donation made will go towards server fees and maintenance costs. -
Hi there, Is anyone saving the Q65H2-AD dump bios file? that should be about 8MB size. Thanks for sharing.
Hi there,
Is anyone having troubles for booting up the Q65H2-AD motherboard that is suddenly stop working?
I found the POST code shows 00 at any time the board run for 1-2 seconds or so... What cause that happens?Comment
Post the PC serial number and your bios backup.Hi there, Is anyone saving the Q65H2-AD dump bios file? that should be about 8MB size. Thanks for sharing.
Hi there,
RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
https://www.badcaps.net/forum/troubl...ore-postingComment
Thanks Gcs_rma for the info, but I cannot find it in Chinafix.com. Could you list the link to the post?Comment
Yes I'll reply to the forum rules of posting.
1. The model : Veriton X4618G
2. The MOB version: Q65H2-AD
3. The PC SN: 13703849892
4. The symptoms found: The BIOS is no longer work after in store a few months back in 2022 thus the PC will not booting up even I checked the POST code of 00 on/off in 2 seconds sequences.
5. The BIOS SPI chip size: 8MB [Do not know if there is a 2nd SPI for BIOS of this model]. The bios file from Acer is only 2 MB, but found the BIOS SPI chip is 8MB size, so requested the dump BIOS 8MB file.Comment
Post your bios backup and we`ll see if it can be fixedYes I'll reply to the forum rules of posting.
There is no bootable BIOS, thus I cannot have any BIOS file extracted from the PC. I know of how to re-flash the dump BIOS of that MOB back to SPI chip that is 8MB size.
Thanks for offering the BIOS fix but first, I need to have a correct, workable dump file of the bios originally from that Q65H2-AD MOB.Comment
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
- Loading...
