thinkcentre m82 bios
  • didouche1200
    • Oct 2016
    • 357
    • 82679911441
    i need dump bios+ec for thinkcentre m82 thinks
    • 20837
    Re: thinkcentre m82 bios
    Post your serial,machine type and bios backup .
    • didouche1200
      • Oct 2016
      • 357
      • 82679911441
      type model 2929
      motherboard is7xm rev 1.0
      buckup bios
      • didouche1200
        • Oct 2016
        • 357
        • 82679911441
        Any help
          • 20837
          Any help
          Here,try these .
          ThinkCentre Edge 92, ThinkCentre M82, M92 and M92p, ThinkStation E31
          Version 9SKT9CA
          • didouche1200
            • Oct 2016
            • 357
            • 82679911441
            not working with 2 beeps
              • 20837
              clear the CMOS using the jumper.Put it on 1+2 start up and leave it for a minute,then press the start button for 10 seconds to shut down.Put the jumper back on 2+3 and start up. You can find where the clear CMOS jumper is in the hardware maintenance manual, page 76
              https://cdn.badcaps-static.com/pdfs/...95171b42da.pdf
              • didouche1200
                • Oct 2016
                • 357
                • 82679911441
                Thanks for help the BIOS work 100%
                • bios-scalper
                  • Jun 2021
                  How did you create these clean dumps? I tested both of your dumps and they work perfectly! Just curious how I can create or clean BIOS dumps.
                  • Last69
                    • Sep 2022
                    • romania
                    guys for you re info , dont upgrade lenovo bios if it s not necesary , i upgrade my m82 to latest bios , because why not and i cant boot from anything (ssd/hdd , usb storage , cd , other ways) , even i change everything on bios legacy and efi eather..leave the lenovo be or dont buy it , later!
                    P.S.: I will try you re bios posted above , mabye i will be lucky
                    • прямо
                      • Sep 2022
                      • 261
                      • Indonesia
                      Originally posted by SMDFlea
                      Here,try these .
                      Version 9SKT9CA
                      Am I correct to assume that I can just load the EC file into a hex editor and replace the MAC address which are located at file offset 0x1000 and 0x2000 with the MAC address from my board?
                      The same goes with replacing the serial number, product number and product name in the BIOS file?
                      I brought mine back to life with a BIOS + EC that I got from Lab-One Inside forum when I searched for IS7XM V1.00 BIOS but because of the MAC address is different, onboard ethernet doesn't work. Detected by Device Manager but can't load driver. If I had edited the MAC address, it'd probably work.
                      • Leonard Fibiger Lewis
                        • Dec 2024
                        • South Africa
                        Did you manage to fix it? I have the same issue...
                        • Vasilescu Florin
                          • Apr 2025
                          • Romania
                          The only way i know that works is to follow this steps. First make from another computer a laptop a bootable usb or cd with the BIOS update and remove the power corde from the computer with the problem.Step 2 open the PC and remove the CMOS battery.Third put the jumper on CMOS reset pin 1 and two.Insert bootable USB and leave it to flash the BIOS and when it reaches 100 % will shut down. Step 4 remove power cord, insert CMOS battery and move the reset pin jumper back to position 2 and 3.Now just restart and all will work.
                          • hotcrossedbuns999
                            M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                            by hotcrossedbuns999
                            My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                            1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                            2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                            3. I could only locate two chips that look like bios chips. Could someone verify this
                            01-03-2025, 12:32 PM
                          • macabook
                            by macabook
                            🧩 Initial Issue
                            07-24-2025, 02:17 PM
                          • amgat
                            BIOS for ThinkCentre M910 Tiny
                            by amgat
                            I need a BIOS dump for ThinkCentre M910 Tiny.
                            The BIOS chip is : Winbond 25Q128JV
                            Board : IQ2X0IH ver 1.0
                            I was using a chip clip with my xgecu pro which led to a corrupt BIOS dump, and the BIOS chip was since re-flashed with the donor BIOS from this thread:
                            https://www.badcaps.net/forum/troubl...nkcentre-m910q
                            This donor BIOS is not working in my system (because...
                            11-22-2024, 02:06 PM
                          • Vesko356
                            by Vesko356
                            08-11-2023, 03:27 AM
                          • jbonavita
                            by jbonavita
                            Some issues
                            Things I tried
                            04-29-2025, 09:38 PM
