iaxbt-bl rev 1.02 bios
  • errold
    • Jul 2016
    • 12
    • philippines
    fellas do you have this bios bin acer aspire
    thanks everyone..
    http://www.mediafire.com/file/dynhy7.../acer.BIN/file
  • errold
    • Jul 2016
    • 12
    • philippines
    Re: iaxbt-bl rev 1.02 bios
    can anyone fix my back up thanks everyone..,
    • peste
      • 13550
      • ROMANIA
      try..
      • errold
        • Jul 2016
        • 12
        • philippines
        its not compatible brother because batt connector voltage over 5v up which is not the normal btw thanks..
        • peste
          • 13550
          • ROMANIA
          if it is an Aspire AIO ZC-606 the bios is compatible because it is made from the Original posted by you, the update on the site, after which the ME region was cleaned ... I don't realize what you measured and how (with the battery in the socket? , with it removed?), (with the desktop on ?, with it off?), where did you measure ??? ... give you more details ... any measurements you made has nothing to do with the bios..check the voltage measuring instrument battery.
          • errold
            • Jul 2016
            • 12
            • philippines
            ok brother thanks ill try your bios again ..the measurement ive done was in cmos bateri and its measure was 5vup which is not normal..maybe other parts were damage no voltage comes out also in 19v dcin..i tried in dc bench current draw was 0.053 injecting direct to main port..thanks brother
            • to5it0
              by to5it0
              10-24-2025, 01:35 AM
            • Citymin
              by Citymin
              S/N : 5RNK9FFT70...
              08-05-2025, 05:12 AM
            • m1ch43lzm
              by m1ch43lzm
              Hi everyone
              09-06-2025, 05:47 PM
            • Forest79
              by Forest79
              07-23-2023, 07:39 AM
            • maanee11
              Help to get Lenovo BIOS bin file for Thinkpad T560
              by maanee11
              Hello Everyone,
              I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
              https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
              In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
              05-15-2022, 11:59 AM
