Asus aio - et2221i maİn board rev 1.2
  • Kartek
    • May 2020
    • 65
    • Türkiye
    ASUS AIO - ET2221I MAİN BOARD REV 1.2
    i need bios dump. my old breakdown is attached. I found a casting, "USB DEVİCE OVER CURRENT STATUS DETECTED !! '' What should I do?
  • peste
    • 13561
    • ROMANIA
    Re: Asus aio - et2221i maİn board rev 1.2
    try .. bios extracted from Asus site update ..
    • Kartek
      • May 2020
      • 65
      • Türkiye
      Thanks for your help, but the result is negative .. first comes to another bios screen but then falls into error like in the photo?
      • Kartek
        • May 2020
        • 65
        • Türkiye
        help?????
        • Kartek
          • May 2020
          • 65
          • Türkiye
          Is there someone helpful about the error in the photo?
          • murat0606
            • Oct 2020
            • 18
            • Earth
            Hi, in my opinion there is a short circuit or over current in USB Devices.
            Regards.
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • DynaxSC
              ASUS STRIX Z490-F GAMING - No POST, stubborn board
              by DynaxSC
              I have this very stubborn ASUS mobo on the bench, and I already face the wall with it. It just refuses to POST, although everything seems to be OK.
              The situation looks like this:
              After connecting the board to the power supply on Nuvoton (SLP_S3#, pin 64), the Low signal (50 ohm resistance) appears immediately. PWRNTN# signal goes through Nuvoton to the chipset (confirmed after removing the chipset). The following conditions are then met for the chipset to generate the SLP_S3# signal:
              1. RTC oscillates normally (32.768KHz).
              07-08-2022, 05:45 AM
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
            • ShadowAi12
              ASUS ROG STRIX B550-F GAMING — Board not powering on properly
              by ShadowAi12
              I recently bought an ASUS ROG STRIX B550-F GAMING motherboard that was listed as "dead, not powering on." However, it does show some signs of life. I've performed several basic measurements and would like to share the results.
              • The board enters a "ready to power on" state after plugging in the PSU.
              • Pressing the power button increases power draw.
              • Sometimes, touching the RSMRST_L pad with a multimeter probe causes the board to shut off and return to standby.
              Measurements:
              (taken after pressing the power button, while the board is attempting to start)
              • H_SKTOOC#
              06-11-2025, 01:05 PM
