iMac A1225 bios dump
  • digitalpc
    • Jun 2016
    • 305
    • .DLL
    Hi i need bios dump for iMac A1225
    3lights up fan no spinning, i can hear cd rom and hdd spin
    no video no sound
    i try reflow gpu same problem
  • basic
    • Oct 2017
    • 229
    • 86357289244
    Re: iMac A1225 bios dump
    bord number ...
    • Habble7
      by Habble7
      Suspected Cause:
      Troubleshooting Attempts:
      05-22-2025, 07:28 AM
    • DynaxSC
      by DynaxSC
      11-17-2023, 10:56 AM
    • grimacelord
      Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
      by grimacelord
      This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
      Motherboard model number: DA0PAMB46A1 REV: A
      Secondary motherboard model number: 0PAB
      SKU: 685K4UA
      Serial number is: 5CD3223BJP
      Recently reflashed this laptop with latest BIOS and once...
      05-07-2024, 08:06 AM
    • DynaxSC
      Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
      by DynaxSC
      I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
      It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
      I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
      11-06-2022, 05:22 PM
    • TacticalFahrrad
      [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
      by TacticalFahrrad
      I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
      06-30-2025, 04:09 AM
