Fix BIOS Dump - Lenovo ThinkCentre E73
  • nrcslim89
    • Nov 2019
    • 129
    • Portugal
    Hello guys, i have an original dump BIOS from one ThinkCentre E73 with almost 8Mb.
    This file makes my machine FAN start loud and fast without POST and after 2Sec. turn's off, and do this in loop sequence everytime.
    I try to flash the BIOS with website official file and the issue seems to go away now the machine turn's on with FAN always running fast and loud with no POST.
    So i presume my original file only needs to be fixed to work well again.
    I drop here my dump, could anyone take a look and fix it please ?
    I want this dump fixed because i want to keep original machine info on file. thanks for your help.
  • Claudiomfa
    • Nov 2015
    • 455
    • Portugal
    Re: Fix BIOS Dump - Lenovo ThinkCentre E73
    Try and report
    • nrcslim89
      • Nov 2019
      • 129
      • Portugal
      Originally posted by Claudiomfa
      Try and report
      Obrigado =)
      I will check and report here.
      • nrcslim89
        • Nov 2019
        • 129
        • Portugal
        Try and report
        Sorry, don't work...
        Machine still Turn ON, FAN spin fast and loud 2 Sec. and Turn OFF without any POST.
          • 21841
          Try this one and report .
          • nrcslim89
            • Nov 2019
            • 129
            • Portugal
            Thanks, programming and testing.
            Report later.
            • nrcslim89
              • Nov 2019
              • 129
              • Portugal
              Hello, thanks for your upload and time, your dump not work.
              Machine keeps the same issue.
              The most strange is whenm i flash the IC with official ROM (4Mb)
              Machine works without looping, but FAN spins fast and loud always and no POST.
                • 21841
                Try this one,its untested .
                • nrcslim89
                  • Nov 2019
                  • 129
                  • Portugal
                  Hello once more, sorry for the delay, i was busy at another issues...
                  BUt i tested this dump too and no lucky... should this is a BIOS Problem ?
                  Or another issue on motherboard ?
                  I ask this because everytime i use 4MB Dump file the machine do another type of issue.
                  BUt when i use everytime the 8MB dump files... goes to the first stage.
                  Turn ON but no POST no image and looping this.
                    • 21841
                    What 4MB file are you using,the extracted bios from lenovo ? ,its only a bios update ,the bios is 8MB .Flash the 8MB bios back .What bios programmer are you using,have you verified the write
                    • nrcslim89
                      • Nov 2019
                      • 129
                      • Portugal
                      Hello, yes i used the last update on website.
                      I will try to download the one with 8MB Mb size.
                      But if you could point me the link to download one i will be thankful.
                      Thanks.
                        • 21841
                        The bios update is only 4MB,there is no full 8MB bios to download from lenovo. The bios at posts 2,5 and 8 are all 8MB .One or all of those should have worked. Your problem is not with the bios .
                        • nrcslim89
                          • Nov 2019
                          • 129
                          • Portugal
                          Thanks for your reply, yes i belive in you, the only thing i suspect at the beggining was the fact that i program the IC and everytime i use the 4MB the machine do another thing.
                          But always i use the 8MB original file or even the posts 2,5 and 8, machine keeps to looping without POST and FAN always at Max speed.
                          Did you suggest any test ?
                          • Claudiomfa
                            • Nov 2015
                            • 455
                            • Portugal
                            use this file and tell the result
                            • rishpin
                              • Dec 2015
                              • 15
                              • kuwait
                              thanks sir this bios is working ,i have same problem fan turn on and off i try this bios & work ... thanks
                              • dejan_bin_laden
                                • Jan 2015
                                • Croatia
                                thx man this fixed my E73
                                • RocketBG
                                  • Sep 2021
                                  Great work. Works fine. Thanks
                                  • HRMD
                                    • Jan 2023
                                    • libya
                                    Hello my friends
                                    I want a copy of the original bios program
                                    • arivera
                                      • Jul 2023
                                      • Puerto Rico
                                      Hey, I just made an account to test this and thank you.
                                      Im having and issue after upgrading to a i7 4790s were the damn pc wont.
                                      complete a restart, it just stays "on"
                                      • OKRPKCOMP
                                        • Dec 2020
                                        • 439
                                        • PAKISTAN
                                        Make bios backup and upload here
                                        Even its updated or not. with serial no and typle/model
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • Forest79
                                          by Forest79
                                          07-23-2023, 07:39 AM
                                        • survivalbloke
                                          Unable to extract bios file from Lenovo bios exectuable
                                          by survivalbloke
                                          I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
                                          Code:
                                          "innoextract 7wcn38ww.exe"
                                          it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
                                          The trouble I'm having is that I'm not getting the newly...
                                          06-12-2024, 07:55 AM
                                        • maanee11
                                          Help to get Lenovo BIOS bin file for Thinkpad T560
                                          by maanee11
                                          Hello Everyone,
                                          I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                                          https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                                          In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                                          05-15-2022, 11:59 AM
                                          LENOVO ThinkCentre ThinkCentre M58p ThinkCentre M E8400 Specification for Upgrade or Repair
                                          This specification for the LENOVO ThinkCentre ThinkCentre M58p can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre ThinkCentre M58p boardview and ThinkCentre ThinkCentre M58p schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                          09-12-2024, 03:36 PM
