Asrock Fatal1ty H87 - Dead after BIOS Update ? (BIOS Dump)
  • Acnologia
    • 428
    • Poland
    I have a 1150 Intel H87 Fatal1ty , which was working great. I made the last Update,of the BIOS and it went dead.
    I tried swapping the A1, B1 BIOS (Dual Chip) and left it , to re-install the BIOS but nothing happened.
    Computer stayed dead, i have CH541 Programmer, which i analyzed both chips ,and they are empty.
    I tried to Program them ,with the BIOS that are online in Asrock site without any luck, the computer / motherboard doesn't even power up it remains dead.
    Does anyone have the BIOS Dump , or what should i check or do ?
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Re: Asrock Fatal1ty H87 - Dead after BIOS Update ? (BIOS Dump)
    A computer should power up even without a BIOS chip fitted. I won't run but it will start.
    Unplug everythin apart from the power lead to the PC
    Remove any add on cards and USB devices
    Disconnect internal hard drives and dvd etc
    Try forcing the ATX power supply on. There are are plenty instructions how to do this
    https://www.youtube.com/watch?v=Ea1dcJ0QyAE
    Do this while the ATX PSU is connected to the motherboard
    Follow me on YouTube
    Learn Electronics Repair
    • Acnologia
      • 428
      • Poland
      It's barebone the motherboard,and plus thanks for the reply.
      I know how to jump start the power supply ,and it was tested with different power supplies.
      It made the BIOS Update, and then it didn't ever came back on ,even without BIOS chip ,it doesn't even spin the FAN of the CPU ,or any lights are showing.
      Is there any eeprom , or any other chip , that you might think ,got "yyyyakes" from the update?
      • dicky96
        Sun Seeker
        • Mar 2017
        • 1825
        • Spain
        Sorry if I am trying to teach you to suck eggs here. It's hard to know what you have already tried or what your experience level is if you don't specifically say. Then I tend to start from the obvious.
        So it sounds like you already did the obvious. Are you saying that the PSU will not start when conencted to the motherboard even if you jump start it with a paperclip or bit of wire?
        Disconnect the 12V supply to the CPU (8 pin connector to motherboard)
        Does it power up now?
        If not check the resistance to ground of all the power rails from the ATX PSU. 3.3V, 5V, 12V etc - are any reading short circuit?
        Measure the voltage between the two pins that connect to the Power On button. Do you have 3.3V there?
        Report back and also let us know what test equipment you have available.
        You may also get more response if you post this thread in the correct section
        https://www.badcaps.net/forum/forumdisplay.php?f=21
        But for now leave it here and maybe a moderator will move it there.
          • 21845
          Bios. H87 Performance(2.60)
          CH541 programmer ? ,do you mean the CH341A . Try using different software with the programmer,try ASProgrammer its a good alternative https://github.com/nofeletru/UsbAsp-...mmer_1.4.1.zip
          • Acnologia
            • 428
            • Poland
            You are right. That i didn't inform you about the obvious that i did.
            No , i mean that the PSU is tested and working 100% on another computer, and i jump started to check in the first place if it was dead,but the PSU is good to go.
            I will try the 12 supply CPU , and report back to you about it.
            I will do also ,all the power rails and report back.
            Thanks once again.
            • Acnologia
              • 428
              • Poland
              Thank you as well, will do it ,right away and report back.
              • mikeybass
                by mikeybass
                04-23-2025, 04:30 PM
              • akwky
                by akwky
                Hi!
                04-14-2025, 01:56 PM
              • Grucha98
                Asrock Fatal1ty B450 Gaming-ITX/ac wont boot, cpu phases turn off after a few seconds. Bios?
                by Grucha98
                Hi I'm working on that asrock motherboard. It had shoted mosfet on cpu phase(changed) and 1 cap on bottom side(changed). Led driver is probably shotted too because voltage on one leg of this chip is 0.5v to 5v (its in loop rising and falling) its's RT7905 and i cant find datasheet :/ But its only led driver so mb should work without it. When i desolder it on the same leg is 5v all the time.
                If i start mb on all cpu phases is 1v1 for a few seconds only. Other voltage are present. So i tried to flash bios with the newest on official site and it doesnt help. Its not normal extension...
                01-19-2025, 03:40 PM
              • al3m0di
                Update bios EFCN58WW to EFCN59WW
                by al3m0di
                Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
                I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
                The BIOS version is EFCN58WW.
                When I turn on the device, it displays the message:
                "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
                The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
                I've tried
                07-29-2024, 10:32 AM
              • DynaxSC
                ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                by DynaxSC
                Hi
                I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                08-04-2025, 12:20 PM
