lenovo C325 DA0QUDM6E0 REV E bios dump needed
  • el panke
    • May 2019
    • 78
    • argentina
    hi folks im looking for this bios dump
    lenovo c325 mother DA0QUDM6E0 REV E
    also theres my backup file
  • el panke
    • May 2019
    • 78
    • argentina
    Re: lenovo bios dump needed
    no 1?
    • el panke
      • May 2019
      • 78
      • argentina
      found it
      • jochydan
        • Mar 2021
        • buenos aires
        Very good contribution to the community, excellent bios
        • Emmasaza
          • May 2021
          • Argentina
          Friend where did you get it from?
          • Emmasaza
            • May 2021
            • Argentina
            Re: lenovo C325 DA0QUDM6E0 REV E bios dump needed
            And how did you manage those files? I have the ch341a, and I saw that there are 4 files, I don't know how to use them.
            • el panke
              • May 2019
              • 78
              • argentina
              Originally posted by Emmasaza
              Y como hiciste para trabajar esos archivos? Yo tengo el ch341a, y vi que son 4 archvos, no sé como utilizarlos.
              https://translate.google.com
              each of those files corresponds to a different chip. the files have in front the number of the chip to which it corresponds, for example U11.
              You look for u11 in the mother and there you have the chip to record
              • Joluvillas
                Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                by Joluvillas
                Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                06-18-2024, 10:35 PM
              • AHmad_Salal
                Need BIOS Dump/ROM for Lenovo Thinkstation p500
                by AHmad_Salal
                Hello all,
                I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                11-28-2023, 05:28 AM
              • DynaxSC
                by DynaxSC
                11-17-2023, 10:56 AM
              • TacticalFahrrad
                [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                by TacticalFahrrad
                I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                06-30-2025, 04:09 AM
              • hirens
                Lenovo ideapad 3 14IGL05 bios dump needed
                by hirens
                model: 81wh
                sn: pf36ta6h
                board no: nm-c961 gs453/gs553
                hey guys above is my laptop info
                it only blinks the power button kindly help me with a working dump
                old dump attached...
                07-21-2023, 04:48 AM
