iMac 27" 5K 2017 bios dump needed
  • andrew25
    • Feb 2016
    • 220
    • Malawi
    Model iMac 27" 5K 2017
    EMC: 3070
    CPU: 3.4GHz
    Board Number: 820-00609-A
    ...urgently wanted...
  • andrew25
    • Feb 2016
    • 220
    • Malawi
    Re: iMac 27" 5K 2017 bios dump needed
    found it
    • rozzzly
      • Sep 2019
      thanks for (not) sharing it
      • rilya
        • Mar 2018
        • 8
        • Italy
        Hi every one, I'm searching this dump also. Is there any oppotunity to download it?
        • inwerp
          • Jan 2012
          • 8
          this thread helped me (not) finding the bios. great job asking for bios and not sharing it after you found it.
          • grmac5
            • Dec 2020
            • 5
            It was on Alisaler but I'm adding it here for those in need:
            • Timp74
              • Apr 2018
              • 36
              • Spain
              Can I just flash this .bin and it will work, or do I need to clean the ME region or do anything else?
              • magneh
                • Apr 2014
                • 585
                • Portugal
                Hi guys,
                Can someone clean ME region of my bios of this 820-00609-A board?
                Late display
                Thank you!
                • aksk
                  • Aug 2017
                  • 5
                  • united kingdom
                  820-00609-A
                  100% working and clean ME
                  • DynaxSC
                    by DynaxSC
                    11-17-2023, 10:56 AM
                  • iZakre
                    HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                    by iZakre
                    Hello everybody!
                    To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                    The thing is that I had installed TeamViewer and could log into the computer...
                    02-19-2023, 02:27 PM
                  • vinaypundith
                    Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                    by vinaypundith
                    I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                    So, I'm looking for a BIOS dump for this machine - a 16MB one....
                    08-03-2024, 12:32 PM
                  • James Maxwell
                    HP DM1-4000er Bios Dump needed
                    by James Maxwell
                    I badly need bios dump for HP DM1-4000er,
                    Model: HP DM1-4000er
                    Motherboard: DA0NM9MB6D0 REV.D
                    Product: QJ490EA#ACB
                    Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
                    10-28-2024, 05:38 PM
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
