Need bios for HP TouchSmart 300-1360 AIO!
  • Mahdix
    • Oct 2019
    • 12
    • Iran
    I need the bios for HP TouchSmart 300-1360. (Some colleague tried to update it and it happened not to boot up any more!) I don't find the file in the manufacture website.
    I will be so thankful if someone could post the bios file and help me with this.
  • eikspaj
    N1NJ4W4RR10R
    • Mar 2015
    • 135
    • Philippines
    Re: Need bios for HP TouchSmart 300-1360 AIO!
    what is the size of the bios?
    can you try this
    There are 10 types of people in the world. Those that understand binary and those that don't.
    • Mahdix
      • Oct 2019
      • 12
      • Iran
      It's 1mb. Thank you. It seems to be the right file. But when I flash it, the PC turns on, screen is off and the fan works in highest speed.
      I guess the problem may be somewhere else!
        • 21853
        try this bios .
        • Mahdix
          • Oct 2019
          • 12
          • Iran
          Dear SMDFlea, It didn't work too.
          Thanks anyway
            • 21853
            Ok, try this one .
            APP78-CF (Jesse) JES5.12
            EDIT: Removed as its the same as the one at post #2
              • 21853
              What CPU does it have,the stock one is an Athlon X2 240e
              • to5it0
                by to5it0
                10-24-2025, 01:35 AM
              • Citymin
                by Citymin
                S/N : 5RNK9FFT70...
                08-05-2025, 05:12 AM
              • m1ch43lzm
                by m1ch43lzm
                Hi everyone
                09-06-2025, 05:47 PM
              • Forest79
                by Forest79
                07-23-2023, 07:39 AM
              • maanee11
                Help to get Lenovo BIOS bin file for Thinkpad T560
                by maanee11
                Hello Everyone,
                I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                05-15-2022, 11:59 AM
