BIOS bin file wanted for Asus M2N-NM/S motherboard
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys
    Does anyone have a bios file for this motherboard which I can use with an external programmer as it is not giving any output onscreen?
    I can't find one on ASUS website for this model, just similar models with onboard video or different number of PCI slots
    Apparently this is an OEM motherboard which is why I am struggling to find a BIOS file.
    best regards
    Rich
    Follow me on YouTube
    Learn Electronics Repair
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Re: BIOS bin file wanted for Asus M2N-NM/S motherboard
    Pic added
    • diif
      • Feb 2014
      • 6978
      • England
      I'm pretty sure it's from a Packard Bell.
      • dicky96
        Sun Seeker
        • Mar 2017
        • 1825
        • Spain
        Probably it is - so with the info that I have where do I find the BIOS file?
        • diif
          • Feb 2014
          • 6978
          • England
          Is this any good ? remember to back up your old one first.
          • dicky96
            Sun Seeker
            • Mar 2017
            • 1825
            • Spain
            Did you forget the attachment?
            • diif
              • Feb 2014
              • 6978
              • England
              My mistake, it was a format not recognised by the uploader.
              It's possible it's not the whole file but an update. Depends on the size of the original.
              • dicky96
                Sun Seeker
                • Mar 2017
                • 1825
                • Spain
                I'll back up the old one and try that, after the weekend
                • dicky96
                  Sun Seeker
                  • Mar 2017
                  • 1825
                  • Spain
                  @diif
                  That file seems to be a complete bin file but for the M2N-NVM version of this motherboard with onboard VGA
                  The board I have is the M2N-NM/S with no onboard VGA, 1xPCIe and 2xPCI slots
                  • dicky96
                    Sun Seeker
                    • Mar 2017
                    • 1825
                    • Spain
                    OK so I decided to make a backup and program with that BIOS file anyway. The Motherboard would then power on and straight back off again with post code 82
                    I then reprogrammed the BIOS from the backup I made and powered on and this time it actually booted up!
                    Now I wondered how this could possible fix the fault. The original problem was that the motherboard would not detect a graphics card -and I had tried several different known good PCIe cards. It would get onto a loop with post code 50 then C1 repeating, give 1 long + 2 short beeps with post code 26 then continue to boot up to FF but with no video output.
                    I didn't actually think this was a BIOS fault but thought I would try program the chip anyway.
                    I realised that this time I had by chance plugged in a different graphics card and it was working, so I then went through my little stash of old GPUs to see what what worked
                    This is what I found
                    GeForce 7300GS (which I commonly use as a known good test card) - not detected
                    GeForce 8500GT (my other commonly used known good card) - not detected
                    Radeon HD3450 (known good) - not detected
                    Quadro FX570 (known good) - not detected
                    ATI X1600 Pro (Known good) - not detected
                    Radeon X300SE (Known good) - not detected
                    Radeon HD2400 PRO - works
                    So the board will boot it is just really fussy what graphics card is fitted
                    Attached is the original working BIN file for Asus M2N-NM/S if it is of any use to anyone else
                    • jbonavita
                      by jbonavita
                      Some issues
                      Things I tried
                      04-29-2025, 09:38 PM
                    • caglarec2268
                      Asus X515EA Bios File Please
                      by caglarec2268
                      merhaba dizüstü bilgisayarım windows ile bios update yaparken kapandı.
                      Now "please follow the steps below to recover your bios" text remains on the screen
                      I tried backup bios files from the site but the keyboard did not work properly or the ssd did not read the disk. Can my bios be repaired? Or is there a correct active bios? please help thank you.
                      laptop model x515ea-bq945w
                      s/n: R4N0CV02K527148
                      CN:HWFB
                      Board model; ASUS X415EA R7.0
                      bios chip: GD25Q128...
                      11-27-2024, 03:51 AM
                    • razor_amd
                      by razor_amd
                      12-15-2020, 07:07 PM
                    • wakethesleep1111
                      Bios File Needed for asus tuf15
                      by wakethesleep1111
                      Hi im new and I have a question. I am in need of a bios file to flash my bios with preferably without the bios password included. I have a Tuf f15 gaming laptop. The model is a TUF506L. The bios chip is a Winbond W25Q128JV. The size is 16777216.
                      05-27-2025, 10:56 PM
                    • eulah
                      help bios bin file for asus ex-a320m gaming motherboard
                      by eulah
                      pls help. fans were spinning but no post, this happened after power failure while updating bios
                      07-16-2024, 01:35 AM
