Guys pls i need bios file bin for hp FX-ISB-1 rev:1.00 /HP 280 G2 MT business PC
  • hussaka
    • Jan 2015
    • 154
    • italy
    thank you
  • monzer-not
    • Mar 2016
    • 22
    • syria
    Re: Guys pls i need bios file bin for hp FX-ISB-1 rev:1.00 /HP 280 G2 MT business
    thank you
    ok 100%
    • hussaka
      • Jan 2015
      • 154
      • italy
      omg thank you so muchhh
      • jerdanty
        • May 2016
        • 3
        • tunisie
        ok
        • YOUN
          • Feb 2015
          • 87
          • Burkina faso
          hi .i need help.bios for fx-isl1 rev 1.0
          thank
          • hobo2566
            • Apr 2014
            • 6
            • Croatia
            Here is MAN A0.07 version of BIOS for HP 280 G2 mt - you can flash it thru recovery by using never USB creation tool, then replacing the bios file with this one and renaming it how it was in the installation. This bios allows SSD drives to be as primary boot devices.
            • abdelilahocs
              • Nov 2018
              • 119
              • morroco
              Originally posted by monzer-not
              ok 100%
              thanks 100 % ok
              • AJ_Brummie
                • Aug 2025
                • 4
                • United Kingdom
                I tried this, changed the jumper settings to BB REC and got 8 beeps, then 2 and 2 in pattern and then no display. My HP is still showing stuck at HP logo at start and cannot go to BIOS and not detecting SSD. This all happened when I updated to latest BIOS. I dont have another HP PC, so cannot create the BIN files. Please help.
                  • 21841
                  If none of the recovery options are working your only option then is to flash the bios with an SPI programmer.
                  • AJ_Brummie
                    • Aug 2025
                    • 4
                    • United Kingdom
                    Thanks for reply. Not sure about SPI Programmer?
                    Maybe I did not format the USB or do not have proper bin file. Can you please check I did create properly:
                    1. I created 10GB FAT32 partition on my 64GB USB on my Dell Laptop.
                    2. I put HP280 G2 mt BIOS A0.07.BIN file on USB.
                    Is there any other BIN Files I can try?
                      • 21841
                      Did you rename the bios
                      • AJ_Brummie
                        • Aug 2025
                        • 4
                        • United Kingdom
                        I did not rename file HP280 G2 mt BIOS A0.07.BIN. What filename should i rename to?
                        I have also attached the system settings and BIOS version A0.25 before I upgraded to latest version.
                        • AJ_Brummie
                          • Aug 2025
                          • 4
                          • United Kingdom
                          Thanks SMDFlea for the guidance. I renamed file to MAN_A046.bin and it all works 😀
                          The key is once you hear 8 beeps, the PC shuts down and restarts. You have to chnage the jumper settings to default otherwise it keeps on restarting.
                          • to5it0
                            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                            by to5it0
                            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                            I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                            This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                            I have opened the laptop and identified the main BIOS chip...
                            Yesterday, 01:35 AM
                          • Citymin
                            by Citymin
                            S/N : 5RNK9FFT70...
                            08-05-2025, 05:12 AM
                          • m1ch43lzm
                            Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                            by m1ch43lzm
                            Hi everyone
                            I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                            Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                            Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                            There's also an extra OTP Secu.R...
                            09-06-2025, 05:47 PM
                          • Forest79
                            by Forest79
                            However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                            07-23-2023, 07:39 AM
                          • maanee11
                            Help to get Lenovo BIOS bin file for Thinkpad T560
                            by maanee11
                            Hello Everyone,
                            I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                            https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                            In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                            05-15-2022, 11:59 AM
