i need dump GA-H61M-S2P (rev. 1.0)
  • salimov
    • Feb 2019
    • 36
    • algeria
    hi everybody
    i need the bios file bin dump of GA-H61M-S2P (rev. 1.0)
    Thank you
    • 20381
    Re: i need dump GA-H61M-S2P (rev. 1.0)
    The full bios is on gigabyte support.
    https://www.gigabyte.com/Motherboard...upport-dl-bios
    • salimov
      • Feb 2019
      • 36
      • algeria
      is file exe i need dump file bin
        • 20381
        The exe is self extracting, run it to extract the files, or you can use 7-zip,winrar,peazip,Universal extractor. The file named h61ms2p3.f6 is the full bios, ignore the .f6 file extension your programmer will read it, or you can rename the file to h61ms2p3.bin
        • salimov
          • Feb 2019
          • 36
          • algeria
          thank you very much
          • bondminer009
            Need Bios for Latitude 7650 (No Original / dump bios file)
            by bondminer009
            Good Evening,
            Need help, is there any possible to get the bios file? Because received from my team without any dump file / original bios file
            Thank You
            Salam,
            Three
            11-12-2024, 07:48 AM
          • joshAU
            BIOS file for N550JK (original dump attached)
            by joshAU
            Hi all.
            I'm looking for a BIOS file for an Asus N550JK.
            I have a Asus R552J, which I believe is identical to the Asus N550JK.
            I downloaded the latest BIOS (210) for the R552.
            It is named N550JKAS.210.
            The BIOS file is however only 6mb in size.
            I've read the chip with a CH341A programmer and verified the file.
            That file is actually 8mb in size.
            I'm wanting to remove the BIOS password from this unit.
            It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...
            08-09-2022, 08:06 PM
          • adelage
            Merge ECS Z77-H2 bios cap file with original dump
            by adelage
            I am trying to recover an ECS Z77-H2 motherboard, I dumped the original bios with a ch341a programmer, the bios from the manufacturer is a .cap file of smaller size, and it seems that I need to merge this file with other information from the dump, anyone can explain how to do that?
            03-11-2025, 03:07 AM
          • silverflea
            Need Bios MSI B75A G43 Dump File
            by silverflea
            Hi. I need dump file bios MSI B75A-G43
            My bios got corrupted and wont boot, so i need to flash it using Ch341A programmer, but bios file from the official website is to large, so i need bios dump file from working motherboard, or anyone know how to cut the bios size to fit bios chip
            Thanks!
            08-09-2022, 01:37 AM
          • iZakre
            HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
            by iZakre
            Hello everybody!
            To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
            The thing is that I had installed TeamViewer and could log into the computer...
            02-19-2023, 02:27 PM
