MSI MS-7885 need schematic or boardview
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3621
    • slovakia
    MSI X99A SLI PLUS
  • on/off
    • Oct 2016
    • 333
    • Indonesia
    Re: MSI MS-7885 need schematic or boardview
    Hope helps you:
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3621
      • slovakia
      many thank mate, but non app can open it. can u tell me what app to use?
      • on/off
        • Oct 2016
        • 333
        • Indonesia
        Mostly I'm using BoardViewer
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3621
          • slovakia
          me too but it giving me error.
          damn on another pc it works. must ben newer version
          • on/off
            • Oct 2016
            • 333
            • Indonesia
            Originally posted by on/off
            I don`t have any issue with software on first link.
            At first time maybe the boardviewer got error, just go to option on tab graphics choose GDI, That's it.
            Maybe only need setting GDI, hope its work.
            • ibnalhabit
              • Mar 2019
              • 52
              • ALGERIA
              many thank
              • xftv5608
                • May 2021
                • 3
                • china
                Thank you very much for your dedication
                • AL._.EX
                  • Dec 2022
                  • 894
                  • Belarus
                  Schematic
                  • slim khab
                    • May 2024
                    • Tunisie
                    Thanks very helpful i can now fix my motherboard
                    • PacoGT
                      HP ENVY x360 gidget 8L 203038-1, boardview and schematic need
                      by PacoGT
                      hello firends
                      i search the schematic or boardview
                      I have this motherboard, but I can't find the schematic or the boardview.
                      The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
                      So the computer doesn't turn on, and the 3V disappears after a few seconds.
                      The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
                      The new problem arose after removing the bad chip.
                      3V and 5V remained together,...
                      08-19-2025, 08:25 PM
                    • hosain0489
                      Request for Schematic and Boardview for HP Omen 16-xf0006AX (AMD Ryzen 7 7840H Version)
                      by hosain0489
                      I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
                      Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
                      If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
                      Thank you very much in advance!
                      07-15-2025, 11:20 AM
                    • re-atari
                      Gigabyte GA-H110-D3A schematic/boardview needed
                      by re-atari
                      Hello all,
                      Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
                      This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
                      02-24-2025, 06:45 PM
                    • jonyhdtv
                      HP ProBook X360 11 G3 ee (winbook) schematic and boardview thanks
                      by jonyhdtv
                      Looking for schematic and boardview
                      Model: HP ProBook X360 11 G3 EE
                      Serial: SCG9114JG7
                      Motherboard: L43774-601
                      defect: touchscreen doesn't work (touch works on another computer)
                      thanks to all​
                      01-29-2025, 08:16 AM
                    • jonyhdtv
                      HP ProBook X360 11 G5 ee schematic and boardview thanks
                      by jonyhdtv
                      HP ProBook X360 11 G5 ee (winbook) schematic and boardview thanks
                      Model: HP ProBook X360 11 G5 EE
                      Serial: SCG0164QLH
                      Motherboard: L83950-601
                      defect: no POWER
                      thanks to all​
                      01-29-2025, 08:11 AM
