M92p Desktop Bios
  • Tcoh
    replied
    Should this BIOS work also on other Serial Number? hoaca388 Or not?
    I flashed it, now i get 3 short + 1 long beep. With original BIOS it didn't beep at all.
    3238
    Model Number AK9
    S/N P8VXVCP (or PBVXVCP, can't tell if it's B or 8)
  • hoaca388
    replied
    Originally posted by clements84
    Hey, I have a m92p tiny that will not post, attached are dumps of chip. multiple reads done, compared the same
    not sure what other info is needed
    Machine Type: 3238
    Model Number: AK9
    S/N: MJTCCLP
    Thanks in advance for your time!
    M92p Desktop (ThinkCentre) - Type 3238
  • clements84
    replied
    Machine Type: 3238
    Model Number: AK9
    S/N: MJTCCLP
    Thanks in advance for your time!​
  • ram128m
    replied
    Re: M92p Desktop Bios
    Originally posted by hoaca388
    M92p Desktop (ThinkCentre) - Type 3209
    It works like a charm.
    Thank you very much!
  • hoaca388
    replied
    Originally posted by ram128m
    This is my read bios(not working) Please help me, Thank you !
    Thinkcentre M92P , Type 3209
    Model Number: 1D3
    S/N: PBF15TD
  • ram128m
    replied
    Model Number: 1D3
    S/N: PBF15TD
  • saqibcomputers
    replied
    Originally posted by SMDFlea
    Try this new bios,your ME area and bios was corrupt. Report back if its working .
    As a side note to all the "Bios Collectors" ,this bios will not work on any other pc without changing some sections with a hex editor !
    100% Working Thanks
  • peste
    replied
    Originally posted by Snttanwar
    Lenovo thinkcentre m92p
    machine type 3227
    model number fa6
    bios please
    always when you make a bios request post the original bios even if it is corrupted...
  • Snttanwar
    replied
    machine type 3227
    model number fa6
    bios please
  • grizzli21
    replied
    Hello , can someone help me with M92p bios?
    I downloaded dumps from chips.
  • hoaca388
    replied
    Originally posted by motes
    my read bios
    Serial number : PB5MYXD
  • motes
    replied
    i need bios for M92p IQ77T ver:1.0 bios and ec bios
    Unfortunatelly not work here bios
    my read bios
  • motes
    replied
  • hoaca388
    replied
    Originally posted by onayteknoloji
    10.240kb you resized
    my main bios is 8.192 kb
    ec bios 2.048kb
    Yes, I split it at #17.
  • onayteknoloji
    replied
    Fixed size
    ec bios 2.048kb
  • hoaca388
    replied
    file size does not match
    Fixed size
  • onayteknoloji
    replied
    M92p Desktop (ThinkCentre) - Type 3227
  • hoaca388
    replied
    hi i have a bios problem can you help me
    Fixed size
  • onayteknoloji
    replied
  • tracker1
    replied
    I confirm that it works.
    Thank you !!!
  • hotcrossedbuns999
    M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
    by hotcrossedbuns999
    My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
    1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
    2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
    3. I could only locate two chips that look like bios chips. Could someone verify this
    01-03-2025, 12:32 PM
  • macabook
    by macabook
    🧩 Initial Issue
    07-24-2025, 02:17 PM
  • grimacelord
    Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
    by grimacelord
    Hello there.
    I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
    History:
    1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
    I searched for this error online and discovered...
    03-15-2023, 03:29 PM
  • AustinCER
    HP ENVY Desktop TE01-1214 - No Display, Powers On, Corrupt BIOS
    by AustinCER
    I currently have an HP ENVY Desktop TE01-1214
    S/N -
    2MO22342GX
    Motherboard - L75365-001
    BIOS Chip - W25Q128JVSQ
    Suspected Windows updates contained BIOS update in which, during update the Desktop PC displayed a black screen to the monitor while still powered on. Display image never restored.
    Tested RAM in both slots, as well as new RAM. Tested a brand new known working i5-10th Gen GPU (Same CPU as original installed). Cleared CMOS. Tested the Desktop PC with a dedicated GPU connected, but still no display. Device will not POST when powered...
    04-25-2025, 05:56 PM
  • Vesko356
    by Vesko356
    08-11-2023, 03:27 AM
