HP 23 AIO PC_23-f205et bios dump please
  • Mcfalsi
    • Apr 2015
    • 193
    • Türkey
    Hi hp all in none pc no power need bios dump please help
    mainboard model IPIVB-AT rev:1.02
  • mahmoodjavan
    Banned
    • Mar 2018
    • 584
    • iran
    Re: HP 23AIO PC_23-f205et
    plz test
    • ziggster
      • Feb 2019
      • 72
      • israel
      i think you should try the bios from the product page first.
      just extract the .exe with winrar and you will have a .bin file in there.
      here:https://support.hp.com/us-en/drivers.../model/5444692
      • ravenmx
        • May 2018
        • 177
        • puebla
        Originally posted by mahmoodjavan
        plz test
        tknks it works
        • mialexia1901
          • Oct 2016
          • 5
          • México
          thank you
          • drscoot
            • Dec 2020
            • 44
            • Belgium
            The LIN_8011.BIN file from mahmoodjavan and on the HP support site are the same.
            But when I compare them with the read out from mu orginal eprom, I don't find any text 'Hewlett' in those files, but in my read out I have several instances. That doesn't look right to me?
            I did have a try with them but still no boot.
            • whitevolf
              • Feb 2014
              • 123
              • TÜRKİYE
              Re: HP 23AIO PC_23-f205et bios dump please
              thanks
              • RIZAL22552255
                • Jul 2022
                • indonesia
                plz test
                thank u, izin sedooottt....
                • jackx
                  • May 2020
                  • 221
                  • casa1
                  hello i need bios +ec PM25LD512 original.BIN​ for
                  IPIVB-AT v1.02
                  lin 8003
                  • jackx
                    • May 2020
                    • 221
                    • casa1
                    IPIVB-AT v1.02
                    lin 8003
                    hello all fix ed problem
                    resistor 220k
                    • yalcinfakir@gmail.com
                      • Dec 2017
                      • 6
                      • TR
                      resistor 220k
                      runing thank you..
                      • inter_cyber
                        • May 2014
                        • 8
                        • turkey
                        resistor 220k
                        Thank you
                        • Ahari
                          by Ahari
                          I...
                          08-13-2025, 06:12 AM
                        • Habble7
                          by Habble7
                          Suspected Cause:
                          Troubleshooting Attempts:
                          05-22-2025, 07:28 AM
                        • haitham sharabati
                          by haitham sharabati
                          Hello engineers 😀,
                          🔧 Device Info:
                          - Model: HP 15-da2007ne
                          - Product Number: 8XF55EA#ABV
                          - Serial Number: CND0338P0D
                          - CPU: Intel Celeron N4000
                          💀 Problem:😅
                          08-07-2025, 04:54 AM
                        • EGUG
                          Bios Dump for Fujitsu Esprimo D7010n with Mainboard D3823-A2 required
                          by EGUG
                          I have a Fujitsu PC with defective bios after bios update from Windows. Therfore I need a bios dump to fix it.
                          Serial number EICK023345
                          Mainboard D3823-A2
                          Hope somebody can help me.
                          04-10-2025, 02:05 AM
                        • Citymin
                          by Citymin
                          S/N : 5RNK9FFT70...
                          08-05-2025, 05:12 AM
