apple imac 820-2828-a bios
  • kesmeseker
    • Jan 2015
    • 121
    • turkey
    ı need 820-2828-a bios dump. plase help me.
  • techman1025
    • Jun 2014
    • 497
    Re: apple imac bios
    Make sure to change serial #
    Techman1025
    • kesmeseker
      • Jan 2015
      • 121
      • turkey
      Re: apple imac bios
      thanks
      • kesmeseker
        • Jan 2015
        • 121
        • turkey
        Re: apple imac bios
        not display
        • techman1025
          • Jun 2014
          • 497
          Re: apple imac bios
          Hi MINE IS 100 % WORKING .If you did the steps after the flash .
          Make sure to do this steps after reflash:
          Resetting NVRAM
          i) Shut down your Apple Mac.
          ii) Locate the following keys on the keyboard: Command, Option, P, and R.
          iii) Turn on your Mac.
          iv) Press and hold the Command-Option-P-R keys immediately after you hear the startup sound.
          v) Hold these keys until the computer restarts and you hear the startup sound for a second time.
          vi) Release the keys.
          And after that... reinstall the OS!
          So let say your original bios work and it stop at password ...i gave you back your orignal file with out password only . You need to run the steps after so the cloud don't reset password. If you have no display you have more then just a password problem did you try a external monitor ?
          Techman1025
          • techman1025
            • Jun 2014
            • 497
            Re: apple imac bios
            Resetting NVRAM
            Techman1025
            Ok im helping many people and i just realized you where NOT the one with passwork locked disregard post before this one . Ok does the old file work? what is exactly the problem i will try and help you.
            Techman1025
            • kesmeseker
              • Jan 2015
              • 121
              • turkey
              Re: apple imac bios
              thanks ... working.test ok
              • marlin297
                • Nov 2022
                • 4
                • africa
                Re: apple imac bios
                Techman1025
                thank you
                • killercuter
                  • Aug 2023
                  • venezuela
                  Re: apple imac bios
                  how to change serial in bios imac
                    • 21874
                    Re: apple imac bios
                    https://www.badcaps.net/forum/showpo...43&postcount=5
                    4.3. Apple
                    For 2017 and older machines, serial number is stored in Fsys store of BIOS and can be edited with hexadecimal editor. Fsys checksum needs to be fixed afterwards
                    Search for "ssn", edit the serial number, save, open dump in UEFITool, go to the Fsys store and write down the suggested checksum in the panel on the right. Checksum is 4 bytes at the end of the Fsys store, between one zone of 0x00 either Gaid or another zone of 0xFF, it must be written in reverse order (so last 2 characters from UEFITool must be written first).
                    See: https://www.youtube.com/watch?v=poA8HByYqTM
                    • mxkosem
                      • Nov 2023
                      • 9
                      • Turkiye
                      Thanks a lot
                      • macabook
                        by macabook
                        🧩 Initial Issue
                        07-24-2025, 02:17 PM
                      • pirati
                        by pirati
                        Yesterday, 04:20 PM
                      • Vesko356
                        by Vesko356
                        08-11-2023, 03:27 AM
                      • jbonavita
                        by jbonavita
                        Some issues
                        Things I tried
                        04-29-2025, 09:38 PM
                      • zenius
                        by zenius
                        12-08-2024, 06:13 AM
