IPPLP-RH TH bios dump
  • kesmeseker
    • Jan 2015
    • 117
    • turkey
    hi. I need dell Dell Inspiron 23" 5348 Motherboard IPPLP-RH/TH rev:a00 bios dump.4mb 8mb and 512kb
    thanks.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: IPPLP-RH TH bios dump
    100% tested dump. Enjoy
    • kesmeseker
      • Jan 2015
      • 117
      • turkey
      oooww thankssss mcplslg123 very very thanks
      • leonic
        • Nov 2018
        • Russia
        thankssss
        • pbls
          • Apr 2019
          • 12
          • Russia
          Thank you so much! It solved my problem.
          • gabrieljma1
            • Jun 2020
            • 13
            • ecuador
            thanks!!!
            • six777
              • Jun 2021
              • 11
              • france
              thank you from france^^
              • mohamed nafees
                • Feb 2023
                • 5
                • Sri Lanka
                thank you
                • amhd61
                  • Oct 2022
                  • 9
                  • ir
                  thank u
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
                  • DynaxSC
                    by DynaxSC
                    11-17-2023, 10:56 AM
                  • grimacelord
                    Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                    by grimacelord
                    This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                    Motherboard model number: DA0PAMB46A1 REV: A
                    Secondary motherboard model number: 0PAB
                    SKU: 685K4UA
                    Serial number is: 5CD3223BJP
                    Recently reflashed this laptop with latest BIOS and once...
                    05-07-2024, 08:06 AM
                  • DynaxSC
                    Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                    by DynaxSC
                    I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                    It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                    I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                    11-06-2022, 05:22 PM
                  • TacticalFahrrad
                    [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                    by TacticalFahrrad
                    I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                    06-30-2025, 04:09 AM
