Inspiron One 2330, power on/off continuously - BIOS
  • hoaca388
    Badcaps
    • Jan 2022
    • 12322
    Re: Inspiron One 2330, power on/off continuously - BIOS
    Originally posted by aboumohamed
    help me
    dell inspiron one 2330 aio turn on but no display on the screen. only the selection menu (hdmi vga computer composite) appear and do a scan.
    I flashed the 03 bios (main+ec+vga board) downloaded on badcaps but no change
    Post your original backup bios.
    • prabajustin
      • Aug 2020
      • 8
      • India
      herewith attached 100% working bios
      • jonrack
        • Feb 2023
        • MEXICO
        thanks its works
        I tell you my situation
        the equipment turned on and stayed on, it did not give anything from POST, only the video input selection, I saw that some turned them on and off, but in this case it only turned on and did not emit any beeps, use the pinout that is previously published
        • kto1983
          • Jul 2016
          • 10
          • chile
          Just delt with one like that. Was the bios. I used a volt meter to figure out the header under the chips and used a cheep programmer off of ebay. The system would power on and display nothing or would get into a power cycling fest. After updateing the bios it beeped an error, i held the power button down till it turned off and next turn on it worked.
          The bios was found on "a Russian site" according to co-worker but couldnt retrace. I have included pictures of the pin out and the programmer connected.
          100% work, deben programar ambas bios
          • Hamza1995
            • Sep 2022
            • 48
            • Algérie
            No show only this message
            Inspiron One 2330 IPIMB-DP REV.A00
            ST/ GNW8VX1
              • 21853
              ST/ GNW8VX1
              Read all of the posts in the topic, there are 2 confirmed working bios, try them..
              • Hamza1995
                • Sep 2022
                • 48
                • Algérie
                #27
                I tried the same problem
                • macabook
                  by macabook
                  🧩 Initial Issue
                  07-24-2025, 02:17 PM
                • zlr8r
                  looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                  by zlr8r
                  looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                  cheers
                  Dell Inspiron 17 (7786) Laptop
                  Service Tag: 5J0NHT2
                  Bios: 1.9.0
                  MOBO: RO 15 17 WHL 2GB MB / 18706-2
                  Attached;
                  1. My saved bios using a programmer
                  2. Dells Bios updater .exe (v1.16)
                  3. Dells Bios recovery file
                  4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                  5. Image of ME...
                  12-18-2023, 03:08 PM
                • pirati
                  by pirati
                  Yesterday, 04:20 PM
                • Vesko356
                  by Vesko356
                  08-11-2023, 03:27 AM
                • sahamipoor
                  need bios dell Inspiron 17 7000 2-in-1 p42e
                  by sahamipoor
                  hi...
                  i need bios of dell Inspiron 17 7000 2-in-1 p42e by chassis Jedi 15/17 cml-mb 18806-1.no display by bios issue.
                  i used and flashed ( dell Inspiron 17 7591) by same chassis and worked .but TMP not detect showing. and not enabling in bios(after each reset disable again). Most importantly the booting up display and startup bios (before windows loading) is too many slow!
                  i updated to latest version and try other version but not working!
                  service tag: HCQ3JW2
                  i need your kind....
                  10-01-2025, 11:10 AM
