Bios dump for apple 820-2143
  • ZOrd_Z
    • Jul 2013
    • 80
    • Portugal
    HI!!
    I need bios dump for apple imac 20. Board is 820-2143-a
    Thanks.
  • techman1025
    • Jun 2014
    • 497
    Re: Bios dump for apple 820-2143
    Hi where is the original file it's alway needed.. Well here is a working file ...it will have a dirty ME REGION for your system . If you don't know how to fix it upload original file i will do it for you.
    Techman1025
    • judamex
      Active Member
      • Jan 2021
      • 186
      • Mexico
      Techman1025
      Works Fine TY
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • bondminer009
        Need Bios for Latitude 7650 (No Original / dump bios file)
        by bondminer009
        Good Evening,
        Need help, is there any possible to get the bios file? Because received from my team without any dump file / original bios file
        Thank You
        Salam,
        Three
        11-12-2024, 07:48 AM
      • joshAU
        BIOS file for N550JK (original dump attached)
        by joshAU
        Hi all.
        I'm looking for a BIOS file for an Asus N550JK.
        I have a Asus R552J, which I believe is identical to the Asus N550JK.
        I downloaded the latest BIOS (210) for the R552.
        It is named N550JKAS.210.
        The BIOS file is however only 6mb in size.
        I've read the chip with a CH341A programmer and verified the file.
        That file is actually 8mb in size.
        I'm wanting to remove the BIOS password from this unit.
        It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...
        08-09-2022, 08:06 PM
      • adelage
        Merge ECS Z77-H2 bios cap file with original dump
        by adelage
        I am trying to recover an ECS Z77-H2 motherboard, I dumped the original bios with a ch341a programmer, the bios from the manufacturer is a .cap file of smaller size, and it seems that I need to merge this file with other information from the dump, anyone can explain how to do that?
        03-11-2025, 03:07 AM
      • m1ch43lzm
        Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
        by m1ch43lzm
        Hi everyone
        I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
        Programmer models: XGecu TL866II Plus / T48 / T56 / T76
        Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
        There's also an extra OTP Secu.R...
        09-06-2025, 05:47 PM
