Please fix this thinkcentre m72z all in 1 bios
  • kazia
    • May 2015
    • 145
    • indonesia
    Please fix this thinkcentre m72z bios
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Please fix this thinkcentre bios
    try this
    Im Back... sort of...
    • Claudio Silva
      • Feb 2013
      • 94
      • Portugal
      Try this one, it is untested
      • hotcrossedbuns999
        M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
        by hotcrossedbuns999
        My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
        1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
        2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
        3. I could only locate two chips that look like bios chips. Could someone verify this
        01-03-2025, 12:32 PM
      • macabook
        by macabook
        🧩 Initial Issue
        07-24-2025, 02:17 PM
      • amgat
        BIOS for ThinkCentre M910 Tiny
        by amgat
        I need a BIOS dump for ThinkCentre M910 Tiny.
        The BIOS chip is : Winbond 25Q128JV
        Board : IQ2X0IH ver 1.0
        I was using a chip clip with my xgecu pro which led to a corrupt BIOS dump, and the BIOS chip was since re-flashed with the donor BIOS from this thread:
        https://www.badcaps.net/forum/troubl...nkcentre-m910q
        This donor BIOS is not working in my system (because...
        11-22-2024, 02:06 PM
      • Kentsfield
        Lenovo Thinkcentre M75n DMI Data extraction from dumped BIOS
        by Kentsfield
        I got a Lenovo Thinkcentre M75n (MT-M 11G5 PF3XG5V3) with a semi-bricked bios.
        Short recap: I want to add an external GPU via the M.2 slot (Oculink). It does work but has some problems with the onboard GPU of the Ryzen 3 3300U. So I used Smokeless_UMAF to disable it. Since then I don't get any video via the external GPU nor the iGPU and Can't access the BIOS, but the PC does boot to the OS.
        I desoldered the flash IC MX25U12872F and dumped the flash.
        I also downloaded the newest BIOS and have it as a .bin file (I loosely compared the contents...
        08-04-2025, 07:46 AM
      • Vesko356
        by Vesko356
        08-11-2023, 03:27 AM
