AsRock H55M-LE
  • aanan
    • Dec 2010
    • 222
    • India
    AsRock H55M-LE
    AsRock H55M-LE REV.G/A1.01 FAN spin but no disply need schematic & bios fiel.
    • 31246
    Re: AsRock H55M-LE
    http://66.226.78.22/downloadsite/bio...E(1.80)ROM.zip
    • aanan
      • Dec 2010
      • 222
      • India
      Re: AsRock H55M-LE
      Thanks friend. need schematic .
      • aanan
        • Dec 2010
        • 222
        • India
        Re: AsRock H55M-LE
        Anyone please.
        • gabrieljma1
          Request: Full BIOS dump for ASRock Z790-CX (DDR5)
          by gabrieljma1
          I’m looking for a full raw 16 MB BIOS dump for an ASRock Z790-CX (DDR5) motherboard.
          The board powers on (fans spin, RGB lights on, RAM LEDs active), but there is no display output and the VGA and BOOT LEDs stay lit.
          I’m using an Intel i9-14900KF CPU (14th gen), and it seems the BIOS version on my board doesn’t support it yet. I tried to flash the official ASRock BIOS file (renamed .ROM → .BIN) directly using my RT809H programmer, but it didn’t work — monitor stays on but with black screen, so I believe the ASRock update file is not a complete...
          10-08-2025, 03:32 PM
        • Exim
          ASRock N100M, no picture no boot, but semi-alive
          by Exim
          Hi guys,
          I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
          ASRock N100M special features:
          - CPU soldered to board, small Intel 12th gen
          - iGPU
          - four POST LEDs
          Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
          I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
          Symptoms:
          - no picture/signal on any of the display connectors,...
          04-01-2025, 02:36 PM
        • MasterCap
          What IC does AsRock usually use to make the PWM signals for GPU fans ?
          by MasterCap
          I have an AsRock Taichi 7900xtx, and the minimum fan speed is way too high at 1000rpm, and thats with it's Quiet BIOS switch on, and me setting the fan profile as low as it goes, while on.
          Now 1 thing I could do is just make some circuit to put in between the fan the the GPU, and leave the fan on all the time, but anytime the GPU is sending the PWM for min speed, I'll just send something lower and quieter.
          But does anyone know what how AsRock usually sends the PWM to the fans on GPUs and mobo's? Is it from the MCU that's often near the 12V inputs and fan jack ? Or is...
          12-28-2024, 08:42 AM
        • nolaryie
          BIOS .bin file for ASRock B450M Steel Legend
          by nolaryie
          Hi, I’m looking for a clean, working BIOS .bin dump (16MB) for the ASRock B450M Steel Legend motherboard.
          I’ve already tried flashing the official ASRock ROM file via CH341A, but it won’t post — I believe the capsule format is incompatible.
          Any BIOS version that supports Ryzen 5 2600 is fine (e.g., P2.30–P3.60).
          If anyone has a working board and can dump the BIOS using CH341A or flashrom, I would really appreciate your help.
          Thank you!
          08-06-2025, 12:01 PM
        • khanhtq0
          Full BIOS Dump for ASRock H310M-HDV Rev 1.02 (MX25L12873F)
          by khanhtq0
          I'm looking for a full BIOS dump (.bin) for the ASRock H310M-HDV Rev 1.02 motherboard. The BIOS chip is a MX25L12873F (128Mb / 16MB).
          I’ve already tried flashing the official BIOS from ASRock (version 1.40 and 3.30), but those are Instant Flash versions and don’t include the full SPI image (e.g. Intel ME Region, Descriptor, etc.). After flashing, the board powers on only when I short PS-ON to ground, and it fails to generate Vcore and 2.5V. Other rails like 1.05V and RAM voltage are present.
          I suspect the original Intel ME and descriptor...
          08-06-2025, 02:14 AM
