🚨 Need Help Reviving an Acer X4690G After Failed BIOS Update
  • codeace110
    • Jul 2025
    • 4
    • Philippines
    Hey guys,
    I tried updating the BIOS on my Acer X4690G, but the power got interrupted mid-update, and now the BIOS is corrupted. The system won’t boot properly anymore.
    Has anyone dealt with this kind of failed flash before? Any tips on how I can recover or fix the BIOS?
    I already searched everywhere for a BIOS dump specific to the X4690G, but I couldn’t find any. If anyone has a working dump, a backup, or knows where I can get one, please let me know.
    Here’s a dump of my corrupted BIOS, and I’ve also included the .CAP BIOS file I downloaded from Acer’s support page.
    Any help would mean a lot — thanks in advance! 🙏
  • hoaca388
    Badcaps
    • Jan 2022
    • 12453
    Originally posted by codeace110
    Hey guys,
    Read chip again, file is corrupted.
    • codeace110
      • Jul 2025
      • 4
      • Philippines
      Hi hoaca388, thank you for the reply. I tried reading the BIOS SOIC16 chip multiple times and it always gives the same file size. I think the chip was wiped during the BIOS update, and then the power got interrupted. This is my first job as a computer tech, and I feel like I messed up badly. I don’t even know what to say to the client anymore… it was an honest mistake though.
      • Wg188
        ACER Veriton Z4660G AIO bios help
        by Wg188
        I have an Acer veriton Z4660G all in one pc,
        Model: Z4660G-I5850H1 (VZ4660G_W)
        Need bios dump and schematic would save my life !
        to make a long story short I bought this all in one used
        with a broken lcd, with the objective of making a custom desktop out of it
        ,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...
        06-17-2023, 02:20 PM
      • Zarithya
        Lenovo ThinkPad X1 Carbon 7th gen not booting after failed BIOS update
        by Zarithya
        I have a ThinkPad X1 Carbon 7th gen that stopped booting after a failed BIOS update. There is no life from the machine when the power button is pressed, but when the charger is plugged in, the amber charging indicator turns on and the power button blinks three times. The battery does charge, eventually turning the amber light white. I've dumped the BIOS and tried to fix it (but I don't know what I'm doing or how to use Lenovo's update files in this way) and even attempted to overwrite it with other uploads I've found here to no avail. I've posted the dump in the request forum and...
        11-02-2025, 06:26 AM
      • Yacine007
        HP victus 16 update bios failed
        by Yacine007
        hello dear friends
        I recently bought this motherboard and I'm having a lot of problems.
        - The Wi-Fi doesn't appear in the Network Card in Device Manager (The Wi-Fi card and the Wi-Fi work fine when I installed the old motherboard)
        - The hard drive is missing when i reboot the system and reappears when i reboot again (crtl+alt+del).
        - When I tried to do an internal BIOS update it doesn't work it always fails.
        Can someone help me update the BIOS or give me a new clean BIOS?
        hp Victus 16-e0xxx
        SN 5CD2050PSQ
        Thank you in advance...
        09-28-2025, 05:30 AM
      • test.it
        Failed bios update on a Dell Precision 3650 Tower
        by test.it
        Can anyone help me with a failed bios update on a Dell Precision 3650 Tower, service tag G01WWM3. The reason for the error was a power failure during the update. System no longer boots, no POST....
        01-28-2025, 07:32 PM
      • al3m0di
        Update bios EFCN58WW to EFCN59WW
        by al3m0di
        Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
        I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
        The BIOS version is EFCN58WW.
        When I turn on the device, it displays the message:
        "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
        The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
        I've tried
        07-29-2024, 10:32 AM
