hp 15s-eq3005nv bios
  • billknt18
    • Apr 2021
    • greece
    I would like to kindly ask for your help regarding a BIOS file for the HP 15s-eq3005nv with Product ID: 6K5H5EA#AB7 and with S/N:5CD2345Z35.
    The motherboard of the laptop is DA0P5MMB6C0 Rev C.
    I have already tried all the available files I could find in this forum, but none of them worked.
    Could you please provide me with, or create for me, the correct BIOS file for this specific model?
    Thank you very much in advance for your time and assistance.
  • m1ch43lzm
    • Mar 2019
    • 1102
    • Peru
    Post the backup you made previous to trying a different BIOS, attach it as .zip or .rar
    • to5it0
      by to5it0
      10-24-2025, 01:35 AM
    • Citymin
      by Citymin
      S/N : 5RNK9FFT70...
      08-05-2025, 05:12 AM
    • maanee11
      Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
      by maanee11
      Hello Everyone,
      I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
      It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
      In the website, you can only see specs etc.
      I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
      11-08-2025, 04:08 AM
    • m1ch43lzm
      by m1ch43lzm
      Hi everyone
      09-06-2025, 05:47 PM
    • Forest79
      by Forest79
      07-23-2023, 07:39 AM
