La-6701p rev 1.0 bios
  • kropotkin
    Oscilloscoopper
    • May 2018
    • 52
    • Republic of Belarus
    Please, need bios dump for this old motherboard:
    PCL31 La-6701p rev 1.0
    • 21836
    Post the PC model number and serial.
    • kropotkin
      Oscilloscoopper
      • May 2018
      • 52
      This is MB from Asus EeeTop PC ET2010AG SN A9PECJ002512 , but few years ago board was replaced by one from Aliexpress. Internet says, that it may contain La-6701p as well as La-5951p.
      Which one it was originally is not known
        • 21836
        There`s a bios at Asus support - https://www.asus.com/us/supportonly/...helpdesk_bios/ .The size is 2MB ,i don`t know if thats a full bios image or an update, probably a full image as it`s AMD. If iyour bios chip is 2MB flash it, if it`s larger post your bios backup.
        • kropotkin
          Oscilloscoopper
          • May 2018
          • 52
          Device came from other service with soldered bios chip. After replacing SB, mobo started respond to power button, but has only backlight with white screen, no image. We tried already bios from official site, - no change, looks like it is from La-5951p. No BIOS for La-6701p in the inernet, unfortunately
          Yes, bios chip is 2 Mb
          • Ahari
            by Ahari
            I...
            08-13-2025, 06:12 AM
          • mkdj
            by mkdj
            Dear all,
            10-19-2025, 04:41 AM
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • haitham sharabati
            by haitham sharabati
            Hello engineers 😀,
            🔧 Device Info:
            - Model: HP 15-da2007ne
            - Product Number: 8XF55EA#ABV
            - Serial Number: CND0338P0D
            - CPU: Intel Celeron N4000
            💀 Problem:😅
            08-07-2025, 04:54 AM
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
