ESPRIMO P9900 E-STARS Bios request
  • OKRPKCOMP
    • Dec 2020
    • 439
    • PAKISTAN
    i dont know how to find Fujitsu pc bios and failed to download it. Pc display problem. board is not faulty, just firmware corrupted
    Board code : W26361-W2051-Z2-04-36
    S.N: YL6N039953
    Backup is attached
    Pls repair and clean bios, thanks in advance
  • hoaca388
    Badcaps
    • Jan 2022
    • 12314
    Fujitsu no longer supports this model.
    https://support.ts.fujitsu.com/IndexDownload.asp
    • OKRPKCOMP
      • Dec 2020
      • 439
      • PAKISTAN
      Sir i have 2 same systems with bios fault, i am uploading both bios files, if no support available then pls clean bios. Maybe it will work
      • TacticalFahrrad
        [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
        by TacticalFahrrad
        I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
        06-30-2025, 04:09 AM
      • dr.thodt
        Fujitsu Esprimo Q956 bios request
        by dr.thodt
        I have this Fujitsu Esprimo Q956 which turns on, but does not post, no video, just full speed fan. For now the bios is suspect.
        I did search for a dump, but I can't find one so hopefully one of you can fix my possibly broken bios.
        Brand: Fujitsu
        Product: Esprimo Q956
        Model: MPC3
        System No.: S26361-K1012-V200
        Part No.: ABN:K1012-V200-586
        Serial No.: YM5G009576
        any of the admins: I'd like to donate for all your services. I did send a private message a while ago, but did not receive an answer....
        08-19-2024, 06:28 AM
      • EGUG
        Bios Dump for Fujitsu Esprimo D7010n with Mainboard D3823-A2 required
        by EGUG
        I have a Fujitsu PC with defective bios after bios update from Windows. Therfore I need a bios dump to fix it.
        Serial number EICK023345
        Mainboard D3823-A2
        Hope somebody can help me.
        04-10-2025, 02:05 AM
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
      • FalconPunch
        Surface Pro X 1876 Bios corrupted
        by FalconPunch
        Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
        Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
        08-09-2025, 03:56 AM
