Gigabyte GA-A320M-S2H BIOS FILE
  • Iamjeeepoy
    • Mar 2025
    • 6
    • Philippines
    Hi masters. can you help me fix this bios?
    post moved....next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
  • peste
    • 13550
    • ROMANIA
    post S/N, full name and model, motherboard model,etc.
    • hoaca388
      Badcaps
      • Jan 2022
      • 12314
      GA-A320M-S2H (rev. 1.x)
      • to5it0
        by to5it0
        Yesterday, 01:35 AM
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • m1ch43lzm
        by m1ch43lzm
        Hi everyone
        09-06-2025, 05:47 PM
      • Forest79
        by Forest79
        07-23-2023, 07:39 AM
      • maanee11
        Help to get Lenovo BIOS bin file for Thinkpad T560
        by maanee11
        Hello Everyone,
        I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
        https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
        In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
        05-15-2022, 11:59 AM
