Need work dump Asus Prime Q270M-C
  • fauzzzyk
    • Jun 2025
    • 9
  • danito
    • Jun 2016
    • 1198
    • Romania
    bios
    • ASB
      Asus Prime B450-Plus Bios Modification (USB Overcurrent)
      by ASB
      I have an Asus Prime B450-Plus motherboard with USB overcurrent shutdown problem. All the ports, voltages and resistors are ok. Can someone please help by editing bios to disable this feature? Another member (прямо) has successfully done this and shared the bios in forum but those are for other Asus models....
      11-12-2025, 06:17 AM
    • DynaxSC
      by DynaxSC
      06-14-2024, 03:49 PM
    • amingpx
      Request dump 8MB asus prime h570-plus r1.02
      by amingpx
      I need this dump thanks for all...
      08-08-2025, 06:20 AM
    • reset1986
      Asus prime b550m-a bios dump
      by reset1986
      Hi guys, I have this PC that does not display an image, video card and GPU and RAM are working, tested on another PC, I suspect the BIOS is damaged, I attach the original dump, I need a working BIOS, thanks...
      06-22-2025, 04:17 AM
    • mkdj
      by mkdj
      Dear all,
      10-19-2025, 04:41 AM
