HP Pavilion 23-b110eg aio pc bios
  • zakrpa
    • Sep 2018
    • 6
    • Bosnia & Herzegovina
    HP pavilion 23 aio pc.
    Sn: czc3030mjg
    pn: d2n09ea#abd
    model no: 23-b110eg
    Cant find any download on hp site. Downloaded bios which it says its for same motherboard but makes it unresponsive / cant even turn on...
    Best regards
    • 21841
    If you have a backup post it.
    • zakrpa
      • Sep 2018
      • 6
      Yea sure, was not home day or two..
      Sorry for for late naswer.
      Thanks in advance
      • m1ch43lzm
        • Mar 2019
        • 887
        • Peru
        Searching for your exact model i can't find anything on HP website, but searching for HP Pavilion 23-b100 i found a support page with drivers/BIOS
        https://support.hp.com/si-en/drivers...series/5330748
        Here's the extracted BIOS, I can't figure out how to copy DMI info, it's stored as NVRAM variables, here's my attempt at it
        Win key 430000h-43003Fh
        DMI 440000h-44154Bh
        DMI2 460000h-46154Bh
        If this doesn't work, flash the clean BIOS also attached, i'm uploading ver 8.16 extracted from HP website (latest is 8.17), then use HP BCU to fill in the remaining data (maybe it's possible to edit System IDs on Security tab, on BIOS setup itself)
        https://ftp.ext.hp.com/pub/caps-soft...it/HP_BCU.html
        Info extracted from your BIOS dump
        Code:
        23-b110eg
        CZC3030MJG
        D2N09EA#ABD
        FBYTE#2V333E3K3N3Q4C4h5c6J6S6b7B7K7M7Q7S7W7s9Sa3ajapaqasauaxaz.t
        BUILDID#13CE1AR8603#SABD#DABD
        Hewlett-Packard
        2AED
        Or
        Code:
        CZC3030MJG
        45EF2F80-08C0-11E2-B0AC-4C72B9D503C4
        CZC3030MJG
        23-b110eg
        103C_53316J G=D
        103C_53307F G=D
        D2N09EA#ABD
        2V333E3K3N3Q4C4h5c6J6S6b7B7K7M7Q7S7W7s9Sa3ajapaqasauaxaz.tE
        Product name: 23-b110eg
        Serial: CZC3030MJG
        UUID: 45EF2F80-08C0-11E2-B0AC-4C72B9D503C4
        SKU: D2N09EA#ABD
        Build ID: 13CE1AR8603#SABD#DABD
        Feature Byte: 2V333E3K3N3Q4C4h5c6J6S6b7B7K7M7Q7S7W7s9Sa3ajapaqasauaxaz.tE
        System Board ID: 2AED
        • zakrpa
          • Sep 2018
          • 6
          Thank you very much.
          ts bit late but I will try it soon as possible. Will let you know how it went
          • sssssssssssssss
            Need BIOS for HP Pavilion 15-n058sr recovery - Caps Lock blinking twice
            by sssssssssssssss
            I'm dealing with a classic BIOS corruption issue on an HP Pavilion 15-n058sr and hoping someone here might have the original BIOS file or point me in the right direction.
            Symptoms:
            • Laptop powers on but no display at all (completely black screen)
            • Caps Lock blinks twice with a pause, then repeats continuously
            • F12 LED stays on permanently
            • No POST, no boot sequence, nothing on screen
            Based on HP diagnostic codes, the 2-blink Caps Lock pattern indicates BIOS corruption/failure.
            What I've tried:
            • Hardware reset (battery removal, power
            09-04-2025, 06:45 AM
            by Vesko356
            08-11-2023, 03:27 AM
          • zenius
            by zenius
            12-08-2024, 06:13 AM
          • lucaszmn
            by lucaszmn
            Problem:
            Initial Findings:
            • I concluded that the
            08-12-2025, 03:01 PM
          • JoWed
            Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
            by JoWed
            Hello Community,
            I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
            07-01-2025, 09:32 AM
