Need bios
W26361-w2051-x03 need bios
Tags: None
Read https://www.badcaps.net/forum/troubl...before-posting and post the PC model number, serial number etc -
Bios for CELSIUS W280 is no longer supported on Fujitsu homepage.↵
https://www.badcaps.net/donateComment
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
Channel: BIOS Requests ONLY!
by Friend33Hello,
I have an EliteBook x360 G3 where I had to replace the motherboard. Everything is working fine and there are no errors during boot. However, I have the issue that the serial number in the BIOS is incorrect. When I run the DMI tool under Windows, I get an error stating that I am not in Unlocked Mode and therefore cannot make any changes. I was able to change the Asset Tag directly in the BIOS. Now I am wondering, can I simply read the BIOS chip, change the serial number with a hex editor, and write it back, or what other options do I have? The old motherboard did not work at... -
by acerRIHi everyone,
We have in company to custom PCs with Gigabyte B760 GAMING X (1.0). When i export hwhash for enrolling PC in azure, i got computer name as MMDEFAULTSTRING.
PCs wiht this name are not compliant with company policy, number should be MMDxxxxxx (xxxxxx is serial number of mb).
I have found that is possible to embbed in BIOS serial number so when i exporting, it will get proper computer name.
Does anyone have know if somehow do that, maybe with some hexeditor, because i have found that some specialized tools are needed.
Any help will be...09-23-2025, 05:26 AM -
by TecnicaNTTHi all,
I got a Lenovo Thinkbook 16P G2 ACH on the bench with a botched BIOS (somehow my client blanked it). I restored the laptop and got it up and running with original BIOS from Lenovo Support website.
My problem is now that the machine details are missing in the BIOS (Serial Number, MTM, etc.)
I tried to write the details with the Lenovo Uone Tool but had now luck. It is giving me an error: "ERROR: Locate protocol with LenovoEeprom, Status=[e]. EEPROM fail when reading or writing data."
I am now asking here for help if anyone knows how to do this in...-
by jackkyxuCan someone help me adding serial number, product name and product ID to this BIOS for a 15-eu1026nr HP laptop?
I had to flash using the BIOS file I downloaded from HP website, but it's missing all info.
Serial: 8CG2205LDR
ProdID: 67W66UA#ABA
Model: 15-eu1026nr...-
- Loading...
