ESC LIVA Z3 PLUS bios dump
  • loveyolanda
    • Apr 2025
    • 6
    • China
    Hello.
    I have an mini pc from ecs.the modle is liva Z3 plus
    I put it long time ago,now it's not working.
    So i want to reflash it with ch431 bios flasher. unfortunately, from ecs site, it just contain rom files.
    Tried to convert it with UEFI tools, but no luck.
    Any one can help me with the ECS Liva Z3 plus bios dump?
    Thanks very much.
    • 20649
    Post your bios backup, even if its corrupt.
    • loveyolanda
      • Apr 2025
      • 6
      • China
      This is my bios dump.thank you!
      • loveyolanda
        • Apr 2025
        • 6
        • China
        This rom file is downloaded from the official website.but not the bin file,I can't reflash it with ch431 bios flasher.​
          • 20649
          It`s not a full bios image, it`s a 12MB update. Your backup has a missing flash descriptor and corrupt/missing CSME firmware. You will need someone to post a bios dump or find a bios dump from another ECS model with Comet Lake firmware to merge the bios update with.
          • loveyolanda
            • Apr 2025
            • 6
            • China
            This is the full bios image.This is a complete bin file synthesized by a Taobao seller using the official website's 12MB rom.But I flash it,it's can't work.
            • tomimc
              • Jul 2015
              • 9
              • spain
              maybe this can help, is a dump on not working device,
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • DynaxSC
                by DynaxSC
                11-17-2023, 10:56 AM
              • grimacelord
                Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                by grimacelord
                This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                Motherboard model number: DA0PAMB46A1 REV: A
                Secondary motherboard model number: 0PAB
                SKU: 685K4UA
                Serial number is: 5CD3223BJP
                Recently reflashed this laptop with latest BIOS and once...
                05-07-2024, 08:06 AM
              • DynaxSC
                Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                by DynaxSC
                I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                11-06-2022, 05:22 PM
              • TacticalFahrrad
                [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                by TacticalFahrrad
                I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                06-30-2025, 04:09 AM
