Ace magician AM06PRO bios request
  • cdsh009
    • Nov 2017
    • 45
    • Venezuela
    Hello, I need the BIOS for a mini PC Ace magician AM06PRO motherboard HCAR4000-MI V:0.3, the mini PC turns on but does not give an image, I hope you can help me thanks
    • 22024
    Post the PC serial number if there is one.
    • cdsh009
      • Nov 2017
      • 45
      • Venezuela
      Hello, it doesn't have a serial number.
      • peste
        • 13691
        • ROMANIA
        The bios posted is longer than it should be....
        The bios chip must be unsoldered from the board before writing or reading..
        do not use the clip, you may have errors..if you do not have anything to unsolder it with,
        solder wires between the programmer and the bios chip..
        here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
        make a correct copy and post again.
        • tay147895412
          HP EliteDesk 705 G1 mini request for bios modding
          by tay147895412
          Hi, I have an HP EliteDesk 705 G1 mini.
          Model: HP EliteDesk 705 G1 Desktop Mini
          Processor: AMD PRO A8-7600B
          Motherboard PCB Marking: "APCB M3 94V-0" / "NPGC N-150TL"
          BIOS Chip: Winbond 25PE20VG (2 Mbit SPI, 3.3V, 8-pin SOIC) and MX25L6473E 64Mbit (8MB), SPI NOR, 3.3V, 8-pin SOIC
          Could someone help me with my bios , request:
          unlock MPM/DMI with a BIOS patch/mod , dc tay42069 if someone could help me pls
          Im gonna leave down below my working bios, if someone could mod it so it has the mpm...
          07-02-2025, 02:23 PM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • zenius
          by zenius
          12-08-2024, 06:13 AM
        • Wahaz
          by Wahaz
          10-30-2023, 08:42 PM
        • hotcrossedbuns999
          M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
          by hotcrossedbuns999
          My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
          1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
          2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
          3. I could only locate two chips that look like bios chips. Could someone verify this
          01-03-2025, 12:32 PM
