HP Elite Mini 800 G9 BIOS Password Unlock
  • alexhoopes
    • Jan 2025
    • 15
    Model: HSC-Q001Dm
    Serial: MXL4102Y9S
    Board: DAF96AMB8G0 REV G
    BIOS and EC (I think) attached.
    Thanks in advance, and if there are any guides into learning how to do this I would appreciate a link! I'd love to learn how to do these instead of coming on here to get the needed files.
  • tony stark
    • Aug 2017
    • 36
    • india
    Originally posted by alexhoopes
    Model: HSC-Q001Dm
    Serial: MXL4102Y9S
    try this
    • alexhoopes
      • Jan 2025
      • 15
      Originally posted by tony stark
      try this
      Thank you. Before I try this, do I need to do anything on the EC chip? I saw in other threads something was required?
      Do you mind sharing what hex was filled with FF to do this?
      Thanks again, I'll give it a shot but just wanna confirm I don't need to flash EC before soldering it back on
      • tony stark
        • Aug 2017
        • 36
        • india
        ONLY FLASH MAIN NOT EC
        • alexhoopes
          • Jan 2025
          • 15
          Flashing my backup and testing now but with your file I was getting 5 red beeps and 7 white lights
          • alexhoopes
            • Jan 2025
            • 15
            No success, same thing, does anyone have any ideas? Could something else have been damaged or do the beeps align with BIOS issue?
            • alexhoopes
              • Jan 2025
              • 15
              I got the computer on, on initial boot there was a message about a mismatch between identities between BIOS and EC. I clicked ok since it said it would recover it and there was no other option. Now when I enter BIOS the password is still there. Are you positive EC does not need flash? what else was I supposed to do here if not?
              • rex98
                • Feb 2023
                • 1278
                • Mandaue CEBU, Philippines
                try this let me know if it boots to mpm mode.
                do not touch the ec
                • alexhoopes
                  • Jan 2025
                  • 15
                  do not touch the ec
                  Flashing now, thank you! Before I go turn on, anything other than F10 I need to press to get to mpm menu after the 3 initial reboots?
                  • alexhoopes
                    • Jan 2025
                    • 15
                    do not touch the ec
                    Got the attached popup on first boot
                    Hit F10 on the next boot and it said entering setup menu then rebooted
                    Hit F10 again and am still getting the password prompt
                    • alexhoopes
                      • Jan 2025
                      • 15
                      Can anyone else help here please?
                      • vanminhscdt@gmail.com
                        • Jul 2022
                        • 71
                        • Việt Nam
                        Can you take a picture of Super IO or its name?
                        • alexhoopes
                          • Jan 2025
                          • 15
                          Where can I find this?
                          • alexhoopes
                            • Jan 2025
                            • 15
                            Is this it, or another chip? Click image for larger version
                              • Jul 2022
                              • 71
                              • Việt Nam
                              There is a high possibility that the password and information are in Super IO .
                              • alexhoopes
                                • Jan 2025
                                • 15
                                Is there a way to reprogram it? There is no recovery method just flashing BIOS/EC? Can someone else confirm if this is true?
                                • minhdigital
                                  • Nov 2022
                                  • 755
                                  • Vietnam
                                  Send to you, try
                                  • alexhoopes
                                    • Jan 2025
                                    • 15
                                    Originally posted by minhdigital
                                    Send to you, try
                                    Flashing chips now and will report back, thank you so much
                                    • alexhoopes
                                      • Jan 2025
                                      • 15
                                      Send to you, try
                                      No dice, same screen with the info being recovered from EC, reboots a few times, first boot into BIOS prompts a password
                                      • alexhoopes
                                        • Jan 2025
                                        • 15
                                        Is anyone else able to help? No success yet
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • volinakis
                                          HP Elite Mini 600 G9 Desktop PC Bios Password
                                          by volinakis
                                          Hi, I need help to remove bios password please.
                                          Name: HP Elite Mini 600 G9 Desktop PC
                                          S/N: 8CC4131WJ8
                                          Prod Id: 4C5J7AV
                                          I did usual modifications to enter in MPM mode but with modifications it restarts several times then when it boots it appears message: "Bios Identity Data Recovered The BIOS has recovered its identity data from the Embedded Controller due to data mismatch" and did not enter in MPM mode.
                                          I attach main and EC backups, maybe Badcaps Masters can help me, thank you in advance.
                                          post moved......
                                          09-10-2024, 12:34 PM
                                        • traxformania
                                          TONGFANG "GM7TG7P" Bios Password Problem?
                                          by traxformania
                                          I tried :
                                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                          11-15-2023, 07:32 AM
                                        • witcher79
                                          Hp Elite Mini 800 G9 Bios Password
                                          by witcher79
                                          Hello
                                          Can anyone remove the bios password from the Hp Elite Mini 800 g9. I am attaching the bios password file. Thank You...
                                          08-02-2023, 01:29 AM
                                        • Nopslide
                                          by Nopslide
                                          04-01-2024, 04:27 PM
