OptiPlex 5080 Small Form Factor Bios
  • lzeta
    • Aug 2020
    • 30
    • Italy
    Hi, I need bios file for OptiPlex 5080 Small Form Factor
    service tag JYL58B3
    I don't have the original dump because I've erase the eeprom and the usb where I've saved original isn't working anymore. I'm trying to recover it.
  • hoaca388
    Badcaps
    • Jan 2022
    • 11813
    service tag JYL58B3
    • lzeta
      • Aug 2020
      • 30
      • Italy
      Thank you so much, witch one I must flash? After flashing have I to insert the service tag in the appropriate section of the bios?
      • hoaca388
        Badcaps
        • Jan 2022
        • 11813
        Yes .
        • lzeta
          • Aug 2020
          • 30
          • Italy
          Please can you help me? I've flashed the
          bin "2 CombineBiosName1 v99.1.45.rar" on winbond W25Q256JV@SOIC16 but the PC doesn't start, no fan, no led nothing. Must I try to flash the other or this is a dual bios and I must flash also the other? I have not seen another eprom to flash, I've desoldered the W25Q256JV and then programmed it with TL866II Plus and all went ok, I've checked the soldering and is ok.
          • lzeta
            • Aug 2020
            • 30
            • Italy
            Bump
            I think I must merge the two bios files (first "name1" and second "name2") and then I must flah it on W25Q256JV. Is it right?
            • hardware1
              • Sep 2021
              • 2938
              • N/A
              Bump
              You have to try both files one by one, because you lost your original backup and we can't know which one is suitable for your device.
              all donations are welcome,
                • 21029
                Look at the xml file. Models are in order ModelName="OptiPlex 5080, OptiPlex 5080-China HDD Protection" .
                CombineBiosName1 - OptiPlex 5080
                CombineBiosName2 - OptiPlex 5080-China HDD Protection
                • hardware1
                  • Sep 2021
                  • 2938
                  • N/A
                  Thanks, I didn't notice that before. So the proper file should be CombineBIOSName1 in his case?
                  I tried to do that with a another device "Dell G15 5511", and the differences was just the Model Number (0x0A70, 0x0A71). In that case I can decide which one to use if I have the original backup, so I can extract the old BIOS region and compare it with the other 2 to see which one is most similar (only if I use the same version).
                  • lzeta
                    • Aug 2020
                    • 30
                    • Italy
                    Thank you so much, I've flashed the "CombineBiosName2 - OptiPlex 5080-China HDD Protection" using a sop16 dip8 adaptor instead of the sop16 dip16 and it starts. Afeter first boot I've typed the service tag in the appropriate section (showed automaticaly on boot) than restarted the system that booted in manifacture programming mode, pressing alt+F (how indicated on boot) it show a menù I had to choose between:
                    OptiPlex 5080
                    I selected the "OptiPlex 5080"
                    Than it started normaly and finally I've updated at last version.
                    I still have doubts that it could also be an adapter problem because in my opinion the PC should have started with both bins. But maybe I'm wrong.
                    • Guilherme Augusto
                      • Mar 2025
                      • 4
                      • Brasil
                      Hi! I program the BIOS file and the desktop (OPTIPLEX 5080 SFF) turned on, but i can't set the service tag. Always when i press alt+F, goes straight to boot. When i try to set in BIOS setup, always when reboot, shows the same screen (MANUFACTURING MODE) and the error continue, saying that service tag is no set. What can i do?
                      • lzeta
                        • Aug 2020
                        • 30
                        • Italy
                        Have you tried to reset cmos? Have you tried to enter bios setup manually? At least you can try to reprogram rom. Normally at first boot it opens bios in the service tag screen.
                        • DenSDen
                          Bios OptiPlex Small Form Factor Plus 7020
                          by DenSDen
                          Hello everyone!
                          I have a PC that does not see either a discrete card or an m2 SSD. The integrated graphics only outputs a picture to one of the three DP connectors. Someone has already flashed the BIOS. I suspect that the BIOS is crooked.
                          Please help me figure this out. I can't figure it out myself. I am attaching backups and markings.
                          Thanks in advance!
                          Service Tag: H9H3R34
                          Express Service Code: 37578223840
                          board vh0216
                          04-04-2025, 09:00 AM
                          HP 280 G2 Small Form Factor PC i3-6100 Specification for Upgrade or Repair
                          This specification for the HP 280 G2 Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 280 G2 Small Form Factor PC boardview and 280 G2 Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                          09-12-2024, 03:44 PM
                          DELL OptiPlex 5080 OptiPlex 5000 i3-10100 Specification for Upgrade or Repair
                          This specification for the DELL OptiPlex 5080 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 5080 boardview and OptiPlex 5080 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                          HP ProDesk ProDesk 600 G2 Small Form Factor PC ProDesk 600 i5-6500 Specification for Upgrade or Repair
                          This specification for the HP ProDesk ProDesk 600 G2 Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 600 G2 Small Form Factor PC boardview and ProDesk ProDesk 600 G2 Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                          09-12-2024, 03:36 PM
