I need bios bin for all-in-one pc enigma 24" serial n" 0001f6
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
08-12-2025, 03:01 PM -
by OscarAVHello,
I am trying to copy the BIOS content, since a user replied to my post in the laptop repair section, and told me that this is a good starting point on my situation. I CAME here, to the BIOS section, and read the guides there, but just to be sure... I downloaded two files, a BIOS configuration utility, sp143621.exe, and a HP UEFI Support Environment, sp61101.exe.
When I run the configuration utility on the cmd,
It gives me an error, system not supported, unable to connect to HP WMI namespace:'root\HP'
Then, I tried to install HP UEFI Support...-
09-26-2024, 08:46 AM -
- Loading...
