Lenovo thinkcentre M70q Gen 2 Logo
  • mtherana
    • 118
    • South Africa
    Can someone please help remove the Third party boot logo on the bios
    Lenovo ThonkCentre Gen 2
    Machine type: 11N0
    SN: PC2GE7RJ
  • fauzanmint
    • Jun 2018
    • 80
    • Indonesia
    Machine type: 11N0
    SN: PC2GE7RJ
    Try this one
    • mtherana
      • 118
      • South Africa
      Originally posted by fauzanmint
      Try this one
      The machine doesn't even switch on with this File no even fan spin.
      now even with the Original backup still bricked
      • volinakis
        • Jan 2021
        • 2872
        • N/A
        it means your backup was corrupted. Usually, if you update bios it will pop up a window with a message about custom logo, if you wanna keep it or not.
        • mtherana
          • 118
          • South Africa
          Try this one
          it went dead after I used this file, are you sure its for the same model this is the motherboard P/N: IB5X0IL2 NM-D331
          or maybe do you have EC file. please
          • mtherana
            • 118
            • South Africa
            Is the no way to fix mine, its very strange I made 2 different backups but with both same results.
            • volinakis
              • Jan 2021
              • 2872
              • N/A
              well, put back original backup, check soldering and let it run for few minutes
              • mtherana
                • 118
                • South Africa
                Hi I did all that, 15min no fan spin no led light, the chip is making contact on all 8 pins. and no other file available anywhere else for M70q Gen 2 HB560 NM-D331 except Vinafix
                  • 21640
                  Did you verify before and after. You have made bad backups before so whats the reason ? ,are you using a clip, is the USB cable ok - try another one. Do you have another programmer you can try etc
                  https://www.badcaps.net/forum/troubl...e2#post3323890
                  https://www.badcaps.net/forum/troubl...g9#post3273024
                  • mtherana
                    • 118
                    • South Africa
                    Hello Sir and thanks for the response
                    I was using the CLIP for backing up. that means the problem began with the Clip and from now I must use the SOP8 Socket
                    how can I verify after backing up? UEFITool and was showing the Intel image was showing 4 Regions
                    and how can I now fix the file on Post #1
                    thank once again I thought by making 2 backups using the clip i will be safe.
                    thank you.
                      • 21640
                      Your backup at post 1 does look corrupt, starting at 16D3D10 with repeated patterns and gibberish until a bit further on where it reads properly again. Its possible the corruption was already there but i`d put the blame on the clip.Only 1 byte needs to be corrupt for the bios not to work,and you wouldn`t see it by looking.
                      Verifying 2 of the same corrupt backups means the backups are the same,and still corrupt.
                      EDIT: It isn`t corrupt, having had a look at the bios update the weird code is the same . The ME firmware is corrupt though
                      • mtherana
                        • 118
                        • South Africa
                        can you please help me fix .
                          • 21640
                          Try this bios.
                            • 21640
                            Try this one
                            It won`t work with unconfigured firmware. Read the ME cleaning guides https://www.badcaps.net/forum/troubl...22#post1622422
                            • mtherana
                              • 118
                              • South Africa
                              Thank you SMD it now works but has SVP.
                                • 21640
                                Post the EC chip part number, and look around the board for unsoldered JTAG ports
                                • mtherana
                                  • 118
                                  • South Africa
                                  Here are the part numbers I couldn't find any jtags and have also tried to clear CMOS jumper
                                  • mtherana
                                    • 118
                                    • South Africa
                                    Try this bios.
                                    another question is the SVP not stored in this Bin file ? since on the corrupted one on POST #1 I was able to change the settings and even disabled computrace. main issue I couldn't get around was to remove the Logo since the official firmware only gave an option update the firmware.
                                    thank you.
                                      • 21640
                                      thank you.
                                      Havn`t had time to look.
                                      • mtherana
                                        • 118
                                        • South Africa
                                        Try this bios.
                                        Can someone please Help remove SVP on this File Please..
                                        LENOVO ThinkCentre M70q ThinkCentre M i5-10400T Specification for Upgrade or Repair
                                        This specification for the LENOVO ThinkCentre M70q can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre M70q boardview and ThinkCentre M70q schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        09-12-2024, 02:00 PM
