Board view and schematics for MSI Mag z490 tomahawk board
  • pavski
    • May 2021
    • 5
    The MSI Mag z490 tomahawk board is not responding to pressing the switch button. There is voltage supplied to BIOS and superio but I would like to trace it. Perhaps somebody could share board view and schematics? Thank you.
  • mjmax7
    • Oct 2022
    • Poland
    I also have the same issue. Can't find the schematic anywhere.
    • Rezistor
      • Jun 2021
      • 370
      • USSR
      • Exchange rare schematics of desktop motherboards, laptops, and video cards for personal use
      MSI MS-7C80 search by platform
      • AL._.EX
        • Dec 2022
        • 943
        • Belarus
        Schematic
        • mjmax7
          • Oct 2022
          • Poland
          ALEX, thanks for schematic !
          Now I'm looking for Boardview CAD file.
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • makinen
            Acer SwiftX 14 SFX14-41G gh4fz LA-L202P Rev 1.0 board view file needed
            by makinen
            MB: Acer GH4FZ LA-L202P Rev 1.0
            Model no: Acer Swift SFX14-41G
            My laptop has random shutdown during use no matter high or low loading since a year ago, but still can be restarted. One day, it got very hot at the bottom near the power chip (PUB1) during use, and finally shutdown when in use and cannot switch on again (like dead), so I suppose there is no major failures and power issue should be fixable.
            There is no visual burnt or component damage, I tracked the power rail that the power seems blocked at charger chip (PUB1), measured some resistors...
            11-10-2025, 03:41 AM
          • hartleyhare5
            Samsung QE65Q9FN — BN44-00944A (65A board) MOSFET failure (relay clicking on one connect) — advice before power-up
            by hartleyhare5
            Post body:
            I'm working on my Samsung QE65Q9FN (65" Q9FN QLED, European model) with relay clicking and no picture. The power supply board in the display itself is the BN44-00944A, known on the board itself as the 65A board (silk-screened designation). There is also a second board, the 65B, which looks identical but is only partly populated for the LED power.
            Symptom: Continuous relay clicking on the one connect — TV will not start up, no picture. However the standby LED is on constantly — so the standby supply rail appears to be alive and the...
            03-26-2026, 03:47 AM
          • DynaxSC
            ASUS STRIX Z490-F GAMING - No POST, stubborn board
            by DynaxSC
            I have this very stubborn ASUS mobo on the bench, and I already face the wall with it. It just refuses to POST, although everything seems to be OK.
            The situation looks like this:
            After connecting the board to the power supply on Nuvoton (SLP_S3#, pin 64), the Low signal (50 ohm resistance) appears immediately. PWRNTN# signal goes through Nuvoton to the chipset (confirmed after removing the chipset). The following conditions are then met for the chipset to generate the SLP_S3# signal:
            1. RTC oscillates normally (32.768KHz).
            07-08-2022, 05:45 AM
