I Need B450M S2H V2 bios dumb bin or rom file
  • onurerer
    • Jan 2021
    • 12
    • Türkiye
    hi everyone i need working bios pls gigabyte b450m s2h v2.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12395
    GIGABYTE B450M S2H V2 (rev. 1.x)
    • onurerer
      • Jan 2021
      • 12
      • Türkiye
      Thanks so much!
      • fcelikel
        • Jan 2019
        • 14
        • türkiye
        Test Ok %100
        • to5it0
          by to5it0
          10-24-2025, 01:35 AM
        • nolaryie
          BIOS .bin file for ASRock B450M Steel Legend
          by nolaryie
          Hi, I’m looking for a clean, working BIOS .bin dump (16MB) for the ASRock B450M Steel Legend motherboard.
          I’ve already tried flashing the official ASRock ROM file via CH341A, but it won’t post — I believe the capsule format is incompatible.
          Any BIOS version that supports Ryzen 5 2600 is fine (e.g., P2.30–P3.60).
          If anyone has a working board and can dump the BIOS using CH341A or flashrom, I would really appreciate your help.
          Thank you!
          08-06-2025, 12:01 PM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • maanee11
          Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
          by maanee11
          Hello Everyone,
          I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
          It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
          In the website, you can only see specs etc.
          I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
          11-08-2025, 04:08 AM
        • m1ch43lzm
          by m1ch43lzm
          Hi everyone
          09-06-2025, 05:47 PM
