GA-A320M-S2H bios bin file
  • pimpjersey2019
    • Dec 2018
    • 5
    • phillippines
    can i request bios for GA-A320M-S2H rev 1.1..thank you
  • leo037_2023
    DEMIGOD OF BIOS
    • Oct 2023
    • 63
    • Buenos Aires - Argentina
    TRY THIS and tell me if work for you..
    • Ahmet USLU
      • Apr 2024
      • Türkiye
      I installed the wrong bios version on my computer, then the computer did not start at all, the bios does not open, I flashed the thousand files you gave me and it did not work. Motherboard model = GA-A320M-S2H rev1.1
      • LUIZ PAULO
        • Jan 2022
        • brazil
        you will find :
        https://www.gigabyte.com/br/Motherbo...upport-dl-bios
        • aegeanxtr
          • May 2012
          • 6
          • turkey
          Tested Working! Thanks
          • Abar
            • Jun 2024
            • India
            Thanks' brother it works for me.
            • Shoaib Laghari
              • Jan 2025
              • 3
              • PAKISTAN
              Bundle Of Thanks working 😍😍😍
              • to5it0
                Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                by to5it0
                Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                I have opened the laptop and identified the main BIOS chip...
                10-24-2025, 01:35 AM
              • Citymin
                by Citymin
                S/N : 5RNK9FFT70...
                08-05-2025, 05:12 AM
              • maanee11
                Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                by maanee11
                Hello Everyone,
                I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                In the website, you can only see specs etc.
                I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                11-08-2025, 04:08 AM
              • m1ch43lzm
                Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                by m1ch43lzm
                Hi everyone
                I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                There's also an extra OTP Secu.R...
                09-06-2025, 05:47 PM
              • Forest79
                by Forest79
                However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                07-23-2023, 07:39 AM
