Galaxy A320M rev g1 bios dump
  • MGL
    • Mar 2022
    • Philippines
    After flashing rom i accidentally enable write protect bios before restarting. The bios hang then not post anything. Any solution?
  • MGL
    • Mar 2022
    • Philippines
    I found out that the board has Ryzen 5 3400G
    but the update excluded this microcode
    so please guys i need bios dump for this..
      • 21604
      You mean Galax not galaxy The bios is available from the galax website - https://www.galax.com/pt/motherboard...therboard.html ,scroll down the page,click on Bios/Drivers Update .Inside the extracted bios folder there is a bios and xlsx spreadsheet with the supported CPU`s
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • Ahari
        by Ahari
        I...
        08-13-2025, 06:12 AM
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • haitham sharabati
        by haitham sharabati
        Hello engineers 😀,
        🔧 Device Info:
        - Model: HP 15-da2007ne
        - Product Number: 8XF55EA#ABV
        - Serial Number: CND0338P0D
        - CPU: Intel Celeron N4000
        💀 Problem:😅
        08-07-2025, 04:54 AM
      • DynaxSC
        by DynaxSC
        11-17-2023, 10:56 AM
