biostar a75mg rev 6.0 bios
  • itsok
    • Aug 2023
    • philippines
    hi everyone im looking for biostar a75mg rev 6.0 bios bin
    thanks in advance
  • hoaca388
    Badcaps
    • Jan 2022
    • 12394
    thanks in advance
    Post backup bios file
    • itsok
      itsok commented
      Editing a comment
      i have save the bios file but i dont think its working cause my mobo still spinning when i turn it on but no post or any sign
  • hoaca388
    Badcaps
    • Jan 2022
    • 12394
    được rồi
    itok
    Tôi đã lưu tập tin bios nhưng tôi không nghĩ nó hoạt động vì mobo của tôi vẫn quay khi tôi bật lên nhưng không có bài đăng hay bất kỳ dấu hiệu nào
    That's why I asked you to post the bios file.
    • itsok
      • Aug 2023
      • philippines
      this is the bin file
    • Citymin
      by Citymin
      S/N : 5RNK9FFT70...
      08-05-2025, 05:12 AM
    • maanee11
      Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
      by maanee11
      Hello Everyone,
      I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
      It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
      In the website, you can only see specs etc.
      I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
      11-08-2025, 04:08 AM
    • m1ch43lzm
      by m1ch43lzm
      Hi everyone
      09-06-2025, 05:47 PM
    • iZakre
      HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
      by iZakre
      Hello everybody!
      To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
      The thing is that I had installed TeamViewer and could log into the computer...
      02-19-2023, 02:27 PM
    • maanee11
      Help to get Lenovo BIOS bin file for Thinkpad T560
      by maanee11
      Hello Everyone,
      I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
      https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
      In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
      05-15-2022, 11:59 AM
