iMac M1 A2438 logic board schematic
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 676
    Seems like a long shot here but I believe I found the issue to the board and can most likely fix it without a schematic however, I would like to make sure what I'm replacing matches the schematic to be 100% certain. Anyone see this online anywhere?
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • JUANDOCH
    • May 2020
    • Switzerland
    Me too, pls I need the schematic for one NO POWER ON
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      Apple MacBook Pro 13" A1706 Logic Board 820-00923 Schematic & Board View
      Apple MacBook Pro 13" A1706 Logic Board 820-00923 Schematic & Board View...
      10-03-2024, 09:51 AM
    • ohren
      Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
      by ohren
      I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
      I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
      The models launched in 2018 and 2019 respectively....
      09-08-2023, 05:24 PM
    • jpreza
      iMac 4K 2019 Logic Board schematic
      by jpreza
      Hey guys,
      Looking for schematics for an iMac 4k 2019 model. For the life of me, I can't figure out why the display will not work. Everything is connected correctly, I don't see any caps or resistors that are damaged. I even swapped the display from another iMac 4k 2019 model to test it, and that display won't work either.
      There are 5 diagnostic LEDs and only 4 light up. The last one does not.
      Any help with schematics would be awesome!
      JP
      04-13-2023, 02:23 PM
    • Yanleb
      LG 60PK550 Logic Control Board EBR63450301
      by Yanleb
      Hi all, I just want to share the repair of my 60PK550-UA TV set.
      The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
      But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
      All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
      C57: 3.30V
      C61:...
      07-20-2023, 12:38 AM
