No Dump for bios solution?
This topic is closed.
  • tahirkhan1983
    • Feb 2012
    • 16
    My question is that when there is no orignal dump bios for new generation mother board then how to to get or rebuild the workimg bios for that?
  • peste
    • 12887
    • ROMANIA
    Re: No Dump for bios solution?
    look for a bios that works, and clean "ME region"..
    • tahirkhan1983
      • Feb 2012
      • 16
      can you find for me HP ProDesk 400 G3 MT MS-7957 with serial number sgh611rdzz. thanks
        • 21058
        There are some threads already posted for the ProDesk 400 G3 ,use the forum search to find them and post your request in one of those related threads.
        Read the rules before you post again !!!
        https://www.badcaps.net/forum/showthread.php?t=103569
        You MUST:
        Requests for password removal or BIOS repair for which the method is available at BIOS guides, methods, resources and tools will not be tolerated anymore if you do not explain why you did not succeed.
        • Ahari
          by Ahari
          I...
          08-13-2025, 06:12 AM
        • Habble7
          by Habble7
          Suspected Cause:
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
        • haitham sharabati
          by haitham sharabati
          Hello engineers 😀,
          🔧 Device Info:
          - Model: HP 15-da2007ne
          - Product Number: 8XF55EA#ABV
          - Serial Number: CND0338P0D
          - CPU: Intel Celeron N4000
          💀 Problem:😅
          08-07-2025, 04:54 AM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • DynaxSC
          by DynaxSC
          11-17-2023, 10:56 AM
