Imac a1224 logic board boardview search
+ More Options
Posts
  • kekoso
    • Aug 2023
    • Russia
    Hi I have a faulty imac a1224. When turned on, 1 LED is constantly on, and also 2 and 3 diagnostic LEDs light up every 5 seconds, and then they immediately go out. I checked the voltages of the power supply when trying to start and they correspond to the declared. I think the fault is somewhere on the motherboard, but I can't find boardview for this model on the forum. Only .sch, no .brd. Can someone share? Thanks
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • ohren
    Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
    by ohren
    I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
    I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
    The models launched in 2018 and 2019 respectively....
    09-08-2023, 05:24 PM
  • Yanleb
    LG 60PK550 Logic Control Board EBR63450301
    by Yanleb
    Hi all, I just want to share the repair of my 60PK550-UA TV set.
    The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
    But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
    All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
    C57: 3.30V
    C61:...
    07-20-2023, 12:38 AM
    Apple iMac A1224 All In One Audio Port Board 820-2136 Boardview
    Apple iMac A1224 All In One Audio Port Board 820-2136 Boardview...
    10-28-2024, 06:00 AM
