Please Bios Asrock AM1B-M
  • Rofix
    • Jul 2023
    • 73
    • Italia
    hello please Bios Asrock AM1B-M
    Thank you
  • volinakis
    • Jan 2021
    • 2800
    • N/A
    Re: Please Bios Asrock AM1B-M
    Thank you
    try (bios extracted from update, v1.50)
    • Rofix
      • Jul 2023
      • 73
      • Italia
      Helloo, thank you
      • veckham
        • Feb 2009
        thank you
        • macabook
          by macabook
          🧩 Initial Issue
          07-24-2025, 02:17 PM
        • DynaxSC
          ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
          by DynaxSC
          Hi
          I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
          08-04-2025, 12:20 PM
          by Vesko356
          08-11-2023, 03:27 AM
        • paulwal
          Updating a BIOS on ASROCK
          by paulwal
          Hi. I am not too up on installing BIOS so am looking for a little direction installing a BIOS update.
          https://www.asrock.com/MB/AMD/AB350%...index.asp#BIOS
          I have an ASROCK AB350 Pro4 that is running a P3.00 BIOS.
          CPU is AMD Ryzen5 1500X which I believe is a "Summit Ridge."
          Before I go ahead and update it to the latest version, I thought I would ask whether my plan is right to try and be sure I don't make a mess of things.
          It appears that the latest BIOS for this chip is the 5.80; therefore I need to install (one at a time)…
          10-02-2023, 04:13 PM
        • nolaryie
          BIOS .bin file for ASRock B450M Steel Legend
          by nolaryie
          Hi, I’m looking for a clean, working BIOS .bin dump (16MB) for the ASRock B450M Steel Legend motherboard.
          I’ve already tried flashing the official ASRock ROM file via CH341A, but it won’t post — I believe the capsule format is incompatible.
          Any BIOS version that supports Ryzen 5 2600 is fine (e.g., P2.30–P3.60).
          If anyone has a working board and can dump the BIOS using CH341A or flashrom, I would really appreciate your help.
          Thank you!
          08-06-2025, 12:01 PM
