HP ProOne 440 G4 bios dump needed .
  • CHaKIR
    • Sep 2022
    • 12
    • Turkiye
    Originally posted by ayman elsherif
    The device worked, but after it was turned on, it performed an update firmware, and then the problem came back again.
    Attached are the original BIOS files.
    I had the same problem. After the update, the device didn't display anything.
    The problem with my computer is that after pressing the start button a few times, the device turns on. Sometimes it doesn't turn on at all. The fans are running, but there is no display.
    SerialNumber: 8CG943CPS6
    Backup bios: *******
      • 21853
      Attach files directly to your post instead of linking to external websites
      • CHaKIR
        • Sep 2022
        • 12
        • Turkiye
        I'm sorry, I missed that.
        • DynaxSC
          by DynaxSC
          11-17-2023, 10:56 AM
        • TacticalFahrrad
          [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
          by TacticalFahrrad
          I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
          BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
          I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
          06-30-2025, 04:09 AM
        • vinaypundith
          Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
          by vinaypundith
          I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
          So, I'm looking for a BIOS dump for this machine - a 16MB one....
          08-03-2024, 12:32 PM
        • James Maxwell
          HP DM1-4000er Bios Dump needed
          by James Maxwell
          I badly need bios dump for HP DM1-4000er,
          Model: HP DM1-4000er
          Motherboard: DA0NM9MB6D0 REV.D
          Product: QJ490EA#ACB
          Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
          10-28-2024, 05:38 PM
        • mkdj
          by mkdj
          Dear all,
          10-19-2025, 04:41 AM
